460 Oil pan-pick up woes milodon stock replacement
Hi,
I
I am freshing up my 460, and after pulling off the stock front sump pan and looking at the mangled rails from 40 years of existence I decided to replace the pan with a stock replacement milodon part number 30745, thats when things went wrong..
I discovered the stock pick up hit the pan by about 3.8 of an inch.
So I made some calls, and did some research and found milodon makes a pick up just for this pan Milodon PN 18645, and ordered it.
It arrived monday only to find out i could push it into the pump with my fingers, and it simply would fall out with little effort.
So, not being the person who rebuild the engine the first time, to eliminate all possibilities I ordered a new Melling M84 pump, thinking that was the issue. Wrong, same result new pump versus old.
So then I called Milodon they said call back the company who I bought it from and get another one, must have been a manufacturing oops.
Tonight got the new replacement 18645, and the same result.
Back on the phone with summit, they recommend I braze it in, I have not brazed in 20 years and was not thrilled with that response. So I called Milodon, and their response was tack the pump and pickup with a mig welder.
Everything I have read from melling, and even on the milodon site they don't recommend welding the cast pump.
The milodon pickup is a snug fit, but by no means a press in fit.
I ordered another pickup from a different vendor today, thinking it might be just a batch related thing.
Has anyone else had this issue?
I
motorcraft88- Posts : 5
Re: 460 Oil pan-pick up woes milodon stock replacement
ya , you have a bunch of wrong stuff
does your pan have a baffle in it? milodon doesn't make a stock replacement pan to speak of,
cj and scj factory pans are deeper
truck pans are not as deep
cj scj takes a diff pump,and pickup tube, because pan is a little deeper, which takes a bolt on tube
stock 460s use a push in tube, and they don't just slide in loose
And for the push in ones I mig weld them in all the time, no big deal
you have to watch the depth, wrong tube with wrong pan and it will block off the oil, wrong pan with wrong tube and it will starve for oil in turns, or stopping
BOSS 429- Posts : 2372
Thanks BOSS 429!
I first tried the generic jegs 460 pan, but didn't really even consider installing it after looking at the rails.
My original set up (the way i bought it) it appears the stock press in screen was riding on the bottom of the pan as well.
Hopefully the replacements ordered yesterday are here tomorrow so I can get it together over the weekend
» Fuel line woes
» Good stock style ign coil replacement?
» Stock spec replacement valve springs/retainers/keepers for SCJ-A heads
» Windsor oil woes.
» question about stock 1971 stock block
» Windsor oil woes.
