Gas pedal assembly
yellowhorse7
6jeff6
Gas pedal assembly
Recommendations for whole gas pedal assembly for my for my 97 cobra. Stock one bent again and I want to switch to a rod style. Sick of cable chit and the pos stock bending .
6jeff6- Posts : 279
Re: Gas pedal assembly
Team Z
yellowhorse7- Posts : 1382
Thanks I'll try them this morning only other one I found that I can modify to work is a http://innovativeracecraftfl.com/shop/fabricated-gas-pedal/
I'll try team z first but I want it before Thursday so I can have done before muscle car day on Sunday
6jeff6- Posts : 279
6jeff6 wrote:Thanks I'll try them this morning only other one I found that I can modify to work is a http://innovativeracecraftfl.com/shop/fabricated-gas-pedal/
Troy Jr does great stuff as well. Can't go wrong with either
Went with team z noone had a rod style one in stock so sticking with lokar cable I guess. Maybe 3rd times the charm...
Thanks man appreciate it . Rock falls new track is bad ass by the way. Nice and smooth
6jeff6- Posts : 279
6jeff6 wrote:Went with team z noone had a rod style one in stock so sticking with lokar cable I guess. Maybe 3rd times the charm...
Careful with the Lokar. Not a bad piece but may want to look into either a factory carb cable (85 mustang) or a rod style linkage deal. You said that the stock pedal bent.....I assume you have a heavy foot lol
Ya I hit it as hard n fast as I can instead of running rpm up on trans brake.
I wanted to go rod style but I would've missed muscle car Sunday as they would've had to make one so I went with z.
Hope it works or I'm spraying to see if I can skip the sand when it sticks haha
6jeff6- Posts : 279
I got sick of fixing busted throttle cables (and losing the occasional race as a result) so I made a couple of quick mods to a B&M shifter cable. Been bulletproof for years.
maverick- BBF CONTRIBUTOR
The problem is the pedal has more travel than length of cable. Make a little pedal stop for it and you won't have any issues...
jbozzelle- Posts : 3705
jbozzelle wrote:The problem is the pedal has more travel than length of cable. Make a little pedal stop for it and you won't have any issues...
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^Yup. Pedal stop is a must.^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Heh, Home Depot 2x4 throttle stop.
DILLIGASDAVE- Posts : 2262
DILLIGASDAVE wrote:Heh, Home Depot 2x4 throttle stop.
LOL. Won many any Index race doing that exact thing.
That makes sense thanks.
6jeff6- Posts : 279
Lol. Hey it works and it's not a car show. I call it genius
6jeff6- Posts : 279
6jeff6 wrote:jbozzelle wrote:The problem is the pedal has more travel than length of cable. Make a little pedal stop for it and you won't have any issues...
I used to "roll" the factory pedal in my Futura towards the trans tunnel from standing on it too much. Ended up shoving something behind the carpet to act as a stop.
maverick wrote:I got sick of fixing busted throttle cables (and losing the occasional race as a result) so I made a couple of quick mods to a B&M shifter cable. Been bulletproof for years.
Great idea!! Any pictures of the setup?
68formalGT- Posts : 865
When I fit my lokar cable I set it so the pedal is on the floor when the carb is at W.O.T. No issues for 5yrs.
BigRigTech- Posts : 763
No stretch issues? What hurt me was pedal assembly was bent for nos wide open switch from last owner then I tried bending it up and reinforcing and like was stated I didn't block it so I put too much stress on the cable.
Now with new assembly and cable I should be fine with either doing floor method or a block .
Appreciate the help and ideas
6jeff6- Posts : 279
I welded a piece of 3/4"x1/8" flat stock to my factory stamped pedal on my 94 and it works great with no flexing issues
The z is awesome. My 60 foot has gone up this year to a 1.5 for some reason (going to slightly tighten band and loosen anti roll) but had best et and mph.
I still may switch to rod style someday but big recommendation for team z pedal assembly if you want to run cable.
6jeff6- Posts : 279
