Oil dip stick
Oil dip stick Empty Oil dip stick
Post  gmsmkr June 5th 2016, 7:43 pm
Blows out when i pull 2ND gear right after burnout .... no smoke from headers the plugs are clean and dry
What im working with is a
472" scj heads
10.8 comp
Alky m1 fuel
Header evacuation
Why is the oil dip stick blowing out under load. It will do this with evac unhooked also
gmsmkr
gmsmkr
Oil dip stick Empty Re: Oil dip stick
Post  6jeff6 June 5th 2016, 7:55 pm
Need evacuation pump I think. My 521 smokes at 6,000+ and I have the evacuation to the back of header to. You must have more pressure
6jeff6
6jeff6
Post  gmsmkr June 5th 2016, 8:04 pm
I was thinking the same thing but it doesn't smoke out the headers
gmsmkr
gmsmkr
Post  6jeff6 June 5th 2016, 8:19 pm
I don't get any issues until I'm in 3rd at the end of the track so maybe your system is working great up top but is letting the pressure stay down low? Hopefully someone can help that has had this issue but all I have seen is vacuum pump to solve it if vent system fails.
Did you get bung in the collector and have a muffler not to far after?
6jeff6
6jeff6
Post  gmsmkr June 5th 2016, 8:40 pm
No mufflers on this deal
gmsmkr
gmsmkr
Post  whitefield June 5th 2016, 8:54 pm
Check and see if your evacuation tube has vacuum on one of the filter / breather where it goes in the Valve cover at idle.
Piston rings may not be seated. Just a thought!
whitefield
whitefield
Post  6jeff6 June 5th 2016, 8:57 pm
My understanding is no muffler, evacuation doesn't happen. Could be why you're not getting oil out exhaust and I am?
6jeff6
6jeff6
Post  gmsmkr June 5th 2016, 9:04 pm
whitefield wrote:Check and see if your evacuation tube has vacuum on one of the filter / breather where it goes in the Valve cover at idle.
Both are pulling vac... it didn't do this on AV gas but I did a cam swap and the alky swap all at once
gmsmkr
gmsmkr
Post  cool40 June 5th 2016, 10:07 pm
A vacuum pump is a very good idea with alky.
Post  rmcomprandy June 6th 2016, 8:18 am
Excessive blow-by originating from somewhere. With alky it a lot of times is bad exhaust valve guides or ring seal.
Vacuum in the crankcase will help this situation but, it needs to be fixed.
Post  gmsmkr June 6th 2016, 12:30 pm
Thanks for all the help I think I'm going to swap back to gas and see what it does beings I need a carb anyway.
It just throwing me a loop cause the motor didn't have many miles on it before the cam and alky swap... most about 150hrs before all the change
gmsmkr
gmsmkr
