Trans cm ember for glide
Glide in a fox, can the stock xmember be used?
Motor is on plates. And what trans mount to use?
tconnection- Posts : 866
Re: Trans cm ember for glide
tconnection wrote:Glide in a fox, can the stock xmember be used?
Stock is fine. cut the little spot welds so you can slide the cross member on the bushings. any trans mount will work. just ask for a 65 impala or something like that. parts store will have to look it up but they are all the same.
whatbumper- Posts : 3024
» glide trans
» TCI trans sheild glide
» power glide trans brake
» New Glide
» Anybody running a full CSR trans/flexplate Supershield for a glide?
» New Glide
