Cranking current draw battery/starter
Last edited by JBR-3 on February 22nd 2020, 2:49 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Cranking current draw battery/starter
JBR-3 wrote:Trying to get a little better handle on this.
Suppose it takes 2-HP to crank an engine ( I don't know how accurate
this guesstimate is, it may be more or less than 2-HP).
2 HP = 1500 watts
At 12 volts cranking, 1500 watts means about 125 amps.
(from V=IR, circuit resistance is then about 1/10 ohm.)
Does the starter actually draw that much current ?
If the battery is drawn down to say 9 volts cranking, that would
indicate about a 90 amp draw, using the same circuit resistance.
(still assuming it takes 2 HP to crank the motor.)
Of course, different engines will need different power to crank.
Anyone measured this or looked into it closer ?
i would say most starters draw way more than that . On average 200-300 amps
mine with 1 red top, power master starter drops to 9.4 to 9.8 volts, this is with ing switch on,and cranking . starts great
volt meter test at firewall solenoid
BOSS 429- Posts : 2372
My starter pulls about 350 amps on 16volts while on. It is only about 100 amps when on the bench with the same battery. On a customers 900+ inch motor the starter we have on it pulls 500 on the hit. Anything else won't spin it over fast enough to fire it. We run 00 wire from battery to starter and it is hot after cranking.
whatbumper- Posts : 3024
JBR-3- Posts : 266
JBR-3 wrote:Thanks guys, I thought my estimate seemed low.
Whatbumper, That is quite impressive, how are you measuring the current draw ?
clamp ammeter
» Starter shim or weak battery?
» What is the draw back
» Starter wiring , with solinoid on starter and fender
» Cranking and idling 580, 14:1
» PLEASE POST PICS OF YOUR ENGINES !!
