Glide to bbf crank bushing
dysan
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Glide to bbf crank bushing
What are you trimming on it?
jbozzelle- Posts : 3705
Gonna trim off the area that suppose to go behind the flex plate,
tconnection- Posts : 866
Gotcha. Makes sense
What I've done now is took an oe spacer an trimmed it for shimming an used it as a template an cut 2 more. They are 1/16 each. Kinda tough making them stay in place on the dial pins. Got bolted up and now have some clearance but auctually to much. Instead of .185 I'm getting .205 which is more than 3/16. So is it safe to shim the converter bolt flange with a washer?
Page 2 of 2 • 1, 2
» WTB NICE STOCK 2Y 460 CRANK, BBF TO GLIDE BELL
» Part number for a glide to BBF crank pilot adapter....
» Rod Bushing Alloy
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» Rod Bushing Alloy
Page 2 of 2
