C6 transmission blanket
I need a good ballistic blanket or shield (I don't know what the better way is these days) Being that I'll be launching in four wheel drive in a 4,000lb truck with 600hp and nitrous. I'm pretty sure I'm going to be hard on drivetrain parts.
Does the blankets gain weight over time? Can you get a blanket with a diaper in it?
jones- Posts : 2230
Re: C6 transmission blanket
put a flexplate shield on and an aluminum TCI or Hughs sfi 4.1 shield on and your good to go !! they don't go off like gernades like a 727 chryco or a thm400
Frank Merkl- Posts : 1524
My brother was telling me that a C6 would explode like a Turbo 400 if I started my burnout in 1st and shifted to second, is that true?
jones- Posts : 2230
not a chance!
1st gear you have clutch pack with a sprag backing it up ,2nd gear the clutch pack releases and the band is applied and holds the direct drum and the sprag overruns
Frank Merkl wrote:1st gear you have clutch pack with a sprag backing it up ,2nd gear the clutch pack releases and the band is applied and holds the direct drum and the sprag overruns
I'm sorry,, didn't see that first post before I typed?
My C6 is a full roller, manual with wide ratio gears and trans brake.
jones- Posts : 2230
NEVER happenjones wrote:My brother was telling me that a C6 would explode like a Turbo 400 if I started my burnout in 1st and shifted to second, is that true?
crittersf1- Posts : 521
crittersf1 wrote:NEVER happenjones wrote:My brother was telling me that a C6 would explode like a Turbo 400 if I started my burnout in 1st and shifted to second, is that true?
That's good! I thought I had asked this a couple of years ago but he was making me doubt myself.
After looking around and reading I don't like the blanket's for my application. I will have to go with the shields.
jones- Posts : 2230
» Automatic Transmission Blanket..
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» Tranny blanket
» PG transmission
» RCI Trans Blanket
» Tranny blanket
» PG transmission
» RCI Trans Blanket
