Caster
Caster
72 Ford pulling truck, highboy style frame,changed front springs to 2 leaf 79 Ford F-250 springs and now the front end has 0 degrees caster. Will this make truck jump or bounce? Where should I need caster to be? This is pulling truck only no street driving. Thanks
Green 72- Posts : 40
Re: Caster
I don't think it would matter.you can always put some wedges in it to see if it changed any but IMO for pulling bring it in a little positive on the toe and let'r eat!
![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif)
Re: Caster
I dont think thats a problem, your hitch height is usually were you get the bounce from, or not running hard tires in the rear,,, at least in my experiences
samiam- Posts : 240
Re: Caster
Toe set at 1/4 in. Hitch hieght is 26 and tires are BFG ATs rears 55-60 psi fronts 20-25. 33-12.50 No weight on front
» need caster cambers
» fox body caster camber adjustment...
» 90-93 Foxbody Caster Camber Plates (NEW)**SOLD**
» Caster camber plate recommendation for my Futura
» Are aftermarket caster camber plates needed with k member for drag only car?
