Dragster cooling systems
Looking for some pictures of cooling setups. My radiator is rear mounted. Haven't bought pump yet. Also curious to see some vac system setups also. Thanks.
Chopperchip- Posts : 63
Re: Dragster cooling systems
Im curious on the cleanest and most durable way to run the lines to the radiator mounted in the rear. Remote pump or a mezier setup
My first (of two) dragsters had a rear mounted radiator. Ran a line from the pump over and down one side of the intake. The other line went down the other side of the intake. I drilled/tapped the water bypass tube hole in the front of the intake to take a fitting.
What size lines? I'm going to reweld the radiator inlet/outlet to except an fittings. Just 1.5 slips right now which I don't like.
Have used -8 on all 3 dragsters running on gas, with remote pumps...
QtrWarrior- Posts : 2703
What brand pumps?
I assume you have an adapter for the water pump inlets to an 8an fitting. Are these made by someone or do I have to rig weld some adapters?
Ok, seen that meziere has a set of -12 block adapters. Also see that that have a 20 gpm pump single in single out.
David, I see how you did your system off the pump. Clean.
Most remote pumps are pipe thread on the inlet and outlet...
I've used the old Teel pumps, which I don't think are available anymore
Have bought some Harbor Freight pumps which are basically the same thing...
Pump is mounted on left side on the frame rail..
Chopperchip wrote:I assume you have an adapter for the water pump inlets to an 8an fitting. Are these made by someone or do I have to rig weld some adapters?
I used a CSR pump and still do. CSR has a -12 fitting for their pump and then I added a -12 to -8 reducer fitting between the fitting and hose end.
I really appreciate the input. I'm in the states to start ordering parts and designing the systems for everything. Not in a hurry. Taking my time. Its a project for my fiance and I. Just in the hunt. Always drag raced mustangs so this is my first dragster build. But it seems a standard mounted electric pump and an in line really isn't going to make or break anything. Seems to be more of a lack is space and personal preference
My radiator in my suncoast
» Dragster cooling systems
» 521 and cooling?
» 64' Fairlane street car w/ 557
» Guys with Foxbody BBF!!!
» Identify Water Pump Markings - PH366 - Overheating problems.... 460
» 521 and cooling?
