Hooking up a duraspark2
Hooking up a duraspark2 Empty Hooking up a duraspark2
Post  65Tremecgt August 5th 2016, 10:26 am
Hey all, in the process of swapping most of a 79 460 C6 truck into my 66 f250. My question is about the factory duraspark2. I'm more families with just running an older style distributor and putting in a pertronix. However I have everything from the 79 and was thinking of trying to run the duraspark2 since j have it. What do I need to hook it up and any other suggestions? Mostly stock setup will be for general truck duty, car hauler and small camper towing. Thanks!
65Tremecgt
Hooking up a duraspark2 Empty Re: Hooking up a duraspark2
Post  jeffgfg August 5th 2016, 5:37 pm
If you look under the sticky at the top of this page marked "Ford ignition" It has a complete diagram of the system and you should be able to wire it from there.
jeffgfg
