p51 heads
p51 heads Empty p51 heads
Post  Rickytx630 August 5th 2016, 4:03 pm
i have a few questions about the p51 heas. in the process of swapping a set of A429cj heads off for a set of p51. my question is as i was being told i cannot use my pushrods that i have now. whats the length and does anyone has a price? kaase doesnt list the price on them? if the pushrods are .100 longer then factory can i use the ones i have or will i need them longer then what i have?
Rickytx630
p51 heads Empty Re: p51 heads
Post  Lem Evans August 5th 2016, 4:36 pm
The rods are not only longer but, the exhaust are longer than the intake.
You'll need a new set of rods. I get about $125 for the 3/8".
Post  Rickytx630 August 6th 2016, 12:54 pm
is that something you keep in stock?
Rickytx630
Post  jbozzelle August 6th 2016, 1:05 pm
You best to check for proper length before you order. There are some slight variances in the rockers from manufacturer to manufacturer that will affect pushrod length.
For example I went from a set of the FRPP A460 blue rockers to a set of the new Comp Ultra Pro Magnum and I need a slightly different length now.
Post  Lem Evans August 6th 2016, 2:33 pm
Rickytx630 wrote:is that something you keep in stock?
I usually drop ship direct from the mfr.
Post  Rickytx630 August 7th 2016, 8:30 pm
good to know. do you have or get the bigger pushrods? 7/16? jw not sure what size ill need. motor will be seeing 7200-7500 weekly .738/.738 roller. bracket motor
Rickytx630
Post  Rickytx630 August 7th 2016, 8:31 pm
jbozzelle wrote:You best to check for proper length before you order.  There are some slight variances in the rockers from manufacturer to manufacturer that will affect pushrod length.
good to know. im running the scorpion 1.73 rockers now. one did break after 13 years of use. ill be buying a new set tho
Rickytx630
