540 CI advice needed
I am into truck pulling and am going to be running a class with a 540 CI limit. I have the goal of 950 horsepower. My heads are trickflow a460 340's that have been ported some. Not sure who did the work or what flow numbers are, but intend to send them out and have them flowed. I am going to run an eliminator block. Without getting into all the specifications, my question is..... What would be better? A 4.500 stroke and smaller piston size, a 4.300 stroke and slightly larger piston, or a 4.140 stroke and a coffee can sized piston. I'm not as worried about torque coming off the line because I am running a slipper clutch and I can come out at high rpm. My concern is I want the engine to maintain rpm when the weight comes on and at the end of the track. But I'm also looking to turn 8500 rpms reliably. Gearing and tire size comes into play as well, but I'm just looking for general advice on the engine right now. Thanks!
Petersonpulling- Posts : 8
Which bore/stroke combination?
A 4.56" bore and a 4.14" stroke (6.8" rod and a 1.43" CH piston, R/S ratio of 1.64) produces 540.89 cubic inches. If there is no leeway on the 540" limit, one could offset grind the crank a touch to get under the 540" limit. The 4.14" stroke results in better rod angularity than the longer strokes and therefore less internal friction at the higher RPMs and the larger bore allows better valve breathing. Torque is a result of displacement, not stroke length.
OR, you could use a 4.625" bore and a 4" stroke for 537.6"s with a 7.1" rod and a 1.2 CH piston for a R/S ratio of 1.775.
On an engine that is going to pull 8500 RPMs over an extended period of time, I believe a larger bore and a shorter stroke would be more reliable and make more power.
What is the intake manifold rule?
Just a thought to get this thread going.
DanE- Posts : 90
Re: 540 CI advice needed
Lunati has a 4.160" crankshaft.
4.530" X 4.160" = 536.38 It'll leave you room for a rebuild and still be legal.
Lem Evans wrote:Lunati has a 4.160" crankshaft.
That sounds like a great combination to me for an aftermarket block build staying around or above 8,000 and higher if you have titanium valves with whatever else is needed.
I have built a couple "filled" D9TE block 540's using "A" heads with steel valves for pulling which were 4.470" bore and 4.300" stroke.
EDIT: There is one of these short blocks going together right now but, for SCJ heads.
DanE wrote:A 4.56" bore and a 4.14" stroke (6.8" rod and a 1.43" CH piston, R/S ratio of 1.64) produces 540.89 cubic inches. If there is no leeway on the 540" limit, one could offset grind the crank a touch to get under the 540" limit. The 4.14" stroke results in better rod angularity than the longer strokes and therefore less internal friction at the higher RPMs and the larger bore allows better valve breathing. Torque is a result of displacement, not stroke length.
No tunnel rams, single carb no size restrictions. I have a trickflow single plane port matched to the heads with plenum work done also. Pic attached
Last edited by Petersonpulling on August 14th 2016, 8:23 am; edited 1 time in total
Lem, that sounds like a good combo.
Rmcomprandy, I have a set of titanium intake valves for the heads, ultra pro Magnum rockers and girdles. Engine will only turn those rpms 300 feet at a time.
For that kind of peak RPM you will want the 4.140 to 4.200" stroke. Flow numbers on heads will have to be known.
Straubtech- Posts : 293
» Piston advice needed
» Advice needed regarding correct starter motor to use.
» Cam advice needed.
» Nitrous advice needed
» Crank advice needed
