and other what will it run
Well the 600 inch doesn't have enough as it will only run 7.17@ 199 mph , sure we won a wally but were going to the Super Street Car Nationals in las Vegas in November, so I plan on taking my best set of C460 heads and put them on my A96 aluminum block 712 cid which has pistons for A441 Boss heads with the pistons .100 down the hole and .495 to the top ring land , flycutting for the C460 valve reliefs will take less than 5 grams out of the pistons so balance shouldn't change much . New Monte Smith Cam (.960 lift) Charlie Evans heads (520 cfm on the best hole @ .950) OKay should we be able @ 2650 lbs be able to run a 6.60-6.70 @ 215-220 mph with about 3000 pph of nitrous . PS were putting the high heels on the car ,ie 10.5W's lol
Frank Merkl- Posts : 1524
Re: and other what will it run
Frank,
It will have enough power to far exceed that goal, but you need to keep it planted on them high heels, do you have any time for test hits before the show.
FalconEh- Posts : 1448
If it didn't I'd burn it!
