c6 Problem? Need more help. ? updated , rebuilt trans is slipping
whitefield
racinghabbit
I have a c6 in my 4x4 mud truck has first and second gear from e40d, bearing, manual valve body, edge pro converter.. launch in second gear shift to third. @3200 on converter
Problem. the stall speed in second gear is starting to climb... went from 3200, to 3500, to 3800, to over 4000 over the course of one day of racing.
so we changed the fluid dark and stinky very little fiber material, so yesterday when we raced we used first gear and just shifted twice... first gear stall @3200 where its supposed to..
What do you think is wrong?
Last edited by racinghabbit on September 13th 2016, 5:33 pm; edited 2 times in total
racinghabbit- Posts : 575
Re: c6 Problem? Need more help. ? updated , rebuilt trans is slipping
racinghabbit wrote:I have a c6 in my 4x4 mud truck has first and second gear from e40d, bearing, manual valve body, edge pro converter.. launch in second gear shift to third. @3200 on converter
Sounds like a hard piston seal causing clutch's to slip and burn. I's start with the forward drum. They seem to like to go first in my experience. This is for the old C6 stuff, don't know much about the E40D conversion deals, suspect the same though.
supervel45- Posts : 4498
Crystal Ball broke , but sounds like over heating the fliud
Frank Merkl- Posts : 1524
Frank... so can i just change the fluid ? It was really hot out...
Are you running any type of cooler ?
whitefield- Posts : 2244
No cooler... short burst of racing 5 second passes.. in mud..
where is the best place to put a transmission gauge on a c6? I do have a b&m aluminum pan
Better put a cooler on that heap. I make short (between 5 and 6 secs.) runs, too....and my trans gets hotter than the hubs of hell if I don't run the fan on the shrouded trans cooler....hot enough to make the t-brake solenoid quit working. You may not be using a brake, but cooking the fluid is cooking the fluid.
maverick- BBF CONTRIBUTOR
racinghabbit wrote:No cooler... short burst of racing 5 second passes.. in mud..
You just diagnosed your problem
Mike R- Posts : 1381
B&m pan should have a 1/8" pipe plug in the side of it for a temp sensor , Change the oil , leaving in 2nd makes the converter work harder making more heat ! a cooler can help ,so can hosing down the trans case and pan with water between rounds , if you cann't hold your hand on the pan - it's to hot !
You need a cooler
Come on give your transmission some love put a cooler on it .I have an 1/8 mile bracket racer .Whenever I come back to the pits after a race my transmission cooler is hot to the touch .I can only imagine how hot yours is .A built c6 with an aftermarket torque is an expensive investment .A cooler will go a long way towards making it last and perform like it should .
manofmerc- BBF CONTRIBUTOR
Transmission is torn apart.... Band cooked, two bushing on the direct drum and forward frictions burnt... I've been running it for 5 years without a cooler , first time it has had a problem... but I will more than likly add one... also a gauge when it goes back in.
5 years on a racing transmission is a long time without a service interval. You got your money's worth out of that one. Replace the clutches, band, and bushings and let it eat! Might want to look at rolerizing it while you are in there if you have time and it's not already done. One of the best investments I've made while I was in mine.
kjett- Posts : 1169
its roller already.
SO..... I had the transmission rebuilt... lasted 8 passes... Added a transmission temp gauge, and cooler.. Transmission never got over 200 degrees ever..... But yesterday when we where at a race , Deep pit. wide open in third and shifted to second because it was bogging down pretty good... and the tires stopped spinning and the rpms just hung out at 5500 for about a second... then let off... during that second the transmission cooler did smoke... as if there was a ton of heat.... but fluid in the pan never showed it on the gauge only jumped 40 degrees that pass. (160-200) ,... any idea's or suggestions. ?
I had one do that and it was the transfer case binding up
crittersf1- Posts : 521
» C6 trans problem
» Torque conv.slipping or over powering
» *Update* 97 Powerstroke trans problem (Attn: Jon)
» The King is slipping
» I think my transmission is slipping
