Hydraulic lifters
Hydraulic lifters Empty Hydraulic lifters
Post  78ranger September 7th 2016, 7:06 pm
Anyone have a preference, brand of lifters they would suggest? Mild 425 hp build. HFT cam. Run it to about 5500 rpm. Don't mind spending a little more money for something good. Thanks.
78ranger
Hydraulic lifters Empty Re: Hydraulic lifters
Post  BBFTorino September 7th 2016, 8:26 pm
Crower!!
Post  rmcomprandy September 7th 2016, 11:34 pm
Personally ... I like the LUNATI "Micro-Trol' hydraulic lifters.
Post  78ranger September 8th 2016, 9:16 pm
Thanks Randy. That was the answer I was looking for. From looking around those were the ones I was thinking about. Appreciate the input as always.
78ranger
Post  Carl September 11th 2016, 8:43 am
I like Lunati's G-series lifter. It has a c-clip retaining the plunger instead of the standard wire.
Carl
Hydraulic lifters Empty Micro Trolls
Post  manofmerc September 13th 2016, 4:04 am
Randy what is the advantage with that Micro Trol lifter ? Are they a bleed down lifter similar to the Rhoads .Just curious because I have a set of the micro trolls in a 428 and they are a little noisey .Doug
manofmerc
Post  rmcomprandy September 13th 2016, 9:02 am
manofmerc wrote:Randy what is the advantage with that Micro Trol lifter ? Are they a bleed down lifter similar to the Rhoads .Just curious because I have a set of the micro trolls in a 428 and they are a little noisey .Doug
Exactly the opposite ... the tolerances are tighter so bleed down is slower. And, they have a slightly shorter travel plunger.
The amount of noise is greatly contributed to by the lobe profile itself and the amount of oil pressure for opperation of that hydraulic lifter.
