Custom built ignition distributors
need a custom built ! need a dizzy to fit you BBF with a tunnel ran with space limitations , I've had to build all my own because there isn't anything that will fit right !! So I'm add to my work load making custom billet dizzy's ,just add to my transbrake VB line
$300 for a crank trigger dizzy , large ford cap, any height , c/w bronze gear
$500 non crank trigger with Ford style pickup and reluctor wheel ,large cap , c/w bronze gear
call 403-793-5412 for more info
Frank Merkl- Posts : 1524
Re: Custom built ignition distributors
Damn Frank, how many hats do you have?
Mike R- Posts : 1381
Just trying to make a living wage ! and there are 24 hours in a day and you can sleep when your dead!
PS , just got the 712 C460 headed monster fired up !!! put's out 20 ft header flames purging threw the motor !! goes on the chassis dyno Saturday to put a baseline tuneup in it for Las Vegas with 3X 40 jet Nitrous kits and were putting the high heels on the car 'aka' 10.5W's
lazy on the engine dyno , N/A only made 1438 hp @ 8350 rpm and 1289 ft/tq @ 5800 rpm but a 119 lobe sep will do that
Frank Merkl wrote:lazy on the engine dyno , N/A only made 1438 hp @ 8350 rpm and 1289 ft/tq @ 5800 rpm but a 119 lobe sep will do that
That is the 1st time ever that I've heard "lazy" and "1438 hp @ 8350 rpm" used together in the same sentence.
kjett- Posts : 1169
I was hoping for 1500+ on motor ! but I put my goals high !! and spraying 3-4 kits I need 2800-3000 rear wheel hp !!!to be competitive! with are 2750 lb car
ps it's BUBBA is a snarely motor !! put it on the transbrake and it will hit the 2step before you have your foot on the floor and on the release tachs 9800 rpm and the rev limits shut it down in less than .2 of a second according ton the data logger and that's just on motor!!
sticky track like vegas we'All show them boy's what a real red neck can run!!
Hope you get video at Vegas Frank.......of the car Frank.....gotta clarify around these guys
John Myrick- BBF CONTRIBUTOR
» Anyone Know where to get Custom Alum. Rad. built?
» FS: 1967 Ford Custom 2 door sedan with '67 Ford Custom parts car (Galaxie body)
» Rebuilding Distributors
» Fully remanned and recurved duraspark distributors
» Selling Spare Parts (Carbs, Distributors, Intake, etc.)
