valve cracking
valve cracking
anybody have any experience with the 5/16 stem 2.400 intake valve cracking on the Ahead ?
steve1071- Posts : 91
Re: valve cracking
steve1071 wrote:anybody have any experience with the 5/16 stem 2.400 intake valve cracking on the Ahead ?
The one that's in the 360 cnc package?
Re: valve cracking
The valve is cracking because it's flexing. Spring pressure or the valve head is too thin. Radial cracks from the seat inward.
gt350hr- Posts : 662
Re: valve cracking
gt350hr wrote: The valve is cracking because it's flexing. Spring pressure or the valve head is too thin. Radial cracks from the seat inward.
Yep, too much cup angle in the face of the valve in my opinion.
Re: valve cracking
yup that's the one < question is what to do ?
Re: valve cracking
has trick flow made a running change ,or should I do something from Manley ,change to 11/32 ?
Re: valve cracking
This. Switch to 11/32.steve1071 wrote:has trick flow made a running change ,or should I do something from Manley ,change to 11/32 ?
Scott Foxwell- Posts : 419
Re: valve cracking
I agree with the 11/32" stem but, it's not "the" issue.
That valve is + .100".....I'm sure Phillip has a job number for a custom Manley valve to replace that unit.
Re: valve cracking
Lem ,would it be possible to get the number for them ? thanks !
Re: valve cracking
steve1071 wrote:Lem ,would it be possible to get the number for them ? thanks !
It is just this kind of thing which makes no sense to me; maybe because I am in business for a living.
Somebody paid the price of probably broken valves, figuring out a solution as to why and then having "Custom" valves made to their specifications in order to solve a distinct problem.
Buy the valves from whoever as they deserve to make a profit from their own misgivings and work; or you are free to figure out your own custom valves.
Why does anyone presume they are entitled to reap the monetary benefits of his testing and figuring it all out ...?
Again, just have him get those valves; (not simply the number so, he is totally by-passed).
It is not the amount which rankles me but, the entitlement thought process of the whole thing within a lot of people.
Re: valve cracking
Buy Titanium and be done with it.
Re: valve cracking
Randy ,all I was asking for was a little help ,if you don't want to then don't . Ill try to be nice because I was taught to ,not because I need to be !
Re: valve cracking
steve1071 wrote: Randy ,all I was asking for was a little help ,if you don't want to then don't . Ill try to be nice because I was taught to ,not because I need to be !
Really...? That's a bunch of crap.
"Being Nice" has nothing to do with it.
The reality IS reality ... and my guess is that you will never understand the difference between "a little help" from "getting exact job numbers of whatever "custom" components are deemed necessary to alleviate an issue, where someone else has spent many hours of their own time and money fixing that same problem".
You're not the only one ... probably half the world has the conception they are the only one's who matter and deserve everything out there whenever they want it.
You got a "little help" telling you where you could probably acquire the valves ... but, that was not enough; you wanted more.
Re: valve cracking
Yes , manley is making me some ! Thanks again Lem for your help !
» cracking C460 heads
» Aluminum Rods cracking
» Exh VAlve ?
» Valve job ?
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» Exh VAlve ?
» Valve job ?
