P51 Head HP gain after head port
Gary Blair
bigblock t-bird
Page 2 of 2
Page 2 of 2 • 1, 2
Re: P51 Head HP gain after head port
Yep, A460's would have been the way to go. What Blake said of the p-51's is true and AFR's may be the new best CJ type head? My next engine may be a 598 with A460's. But for now the 528 with P-51's will haft to do. Thanks Steve
bigblock t-bird- Posts : 201
What about the A460's will a 2.3" or a 2.35" valve clear a 4.390 or a 4.44 bore?Lem Evans wrote:"I have had them on 4.400 to a 4.600 and didn't affect the flow, I would suspect the valve moved so far of the cylinder wall is why."
Yep, that SCJ/P51 intake valve is waay off the cyl. wall.....this is only a 4.400" bore:
mudtrucker- Posts : 160
bigblock t-bird wrote:Gary, so far my best run in the heat was a 5.21 @ 136. I think I may just run it harder? Steve
Sounds like you have a fun ride. Trapping 136 is impressive. How do you like the GRP rods? I run them as well in my 618 and hoping to get a second season out of them in 2017.
99zx9r- Posts : 39
Before I went with the GRP's spoke with my engine builder about there life span. He called them and was told with my combo and rpm range, that 300 1/8 mile passes on there rod's. The motor turn's up fast with them. I do warm up the engine, shut off at the end of all run's. All this helps with engine life. I have only made 39 passes on them this hole year! So look's as if 3 years or so before I look at changing them. Steve
bigblock t-bird wrote:Before I went with the GRP's spoke with my engine builder about there life span. He called them and was told with my combo and rpm range, that 300 1/8 mile passes on there rod's. The motor turn's up fast with them. I do warm up the engine, shut off at the end of all run's. All this helps with engine life. I have only made 39 passes on them this hole year! So look's as if 3 years or so before I look at changing them. Steve
Getting 300 passes wouldn't be bad at all. I'm hoping for 180-200...quarter mile, but on the throttle stop and going through at 7200.
99zx9r- Posts : 39
Page 2 of 2 • 1, 2
» c head exhaust port
» who's port ?
» to the Evans? head port work
» Speedmaster 460 Head Exhaust port size
» Best Valve Combination to run on BT Chevy Ext. Port Head
» who's port ?
Page 2 of 2
