Knotching cyllinder walls
+7
wilmus
gt350hr
75truck
11 posters
I have oversize valves on a 429, heads are D3ve-A , intake 2.25 and was wondering if I should notch the cylinder edge next to the intake valve?
My compression ratio is around 9.8:1.
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Knotching cyllinder walls
+1 no reason for it.
gt350hr- Posts : 662
Put the head on the block, make a hook scribe and scribe the chamber around the cylinder. Might give you something to think about.
Scott Foxwell- Posts : 419
Not needed with that combo.
Do any heads need that to happen on a stock block?
Meaning do the SCJ's or P51's with the larger valves?
or even the A460 with the 2.35 valves?
wilmus- Posts : 5
wilmus wrote: Do any heads need that to happen on a stock block?
I think KJett notched his for his A460 build. I'm not sure of his valve size though.
68formalGT- Posts : 865
I don't look at it form a valve size point of view, I look at how the cylinder fits the chamber (or vise verse). It might help cylinder head flow a little but how about flame propagation from the chamber into the cylinder?wilmus wrote: Do any heads need that to happen on a stock block?
The TFS A460 chamber is the one that is wider that most bores.
I guess what I was asking is would there be any valve contact on a stock block with stock bore if any of those heads were used?
I saw a pic that Lem posted (I think) that showed a fairly large amount of space between a cyl bore and the SCJ heads and its valves
I was wondering if the TFS A460 heads had enough room as well ?
As to not have the valves hit a stock BBF 460 bore?
wilmus- Posts : 5
75truck wrote:I have oversize valves on a 429, heads are D3ve-A , intake 2.25 and was wondering if I should notch the cylinder edge next to the intake valve?
Bob
Tucson
Some cylinder heads have chambers bigger than the bore ... I believe that the D3VE chambers are not.
My Motorsport A460 heads with a 2.35" Intake valve had to have notches on a 4.39" bore block. No notches were needed when I switched to a 4.44" bore block.
FWIW Mark
FWIW Mark
Mark Laczo- Posts : 274
68formalGT wrote:wilmus wrote: Do any heads need that to happen on a stock block?
I did on my 4.42 bore block. The valves did barely cleared the walls, but we did it more to help unshroud the valve more with such a small bore and big head. It worked out well for my application/build, but may not be needed for another.
kjett- Posts : 1169
wilmus wrote: I guess what I was asking is would there be any valve contact on a stock block with stock bore if any of those heads were used?
Factory heads with 2.25 valves do not need notched on a 4.36 stock bore
Just curious, I have had to notch small bore with blue thunder heads is this normal? I just copied the notches from a 351c. Still pretty close with a 4.390.
slurm- Posts : 103
slurm wrote:Just curious, I have had to notch small bore with blue thunder heads is this normal? I just copied the notches from a 351c. Still pretty close with a 4.390.
Can't speak for the BT heads if they had 1.88 exhaust valves and Chevy ports never played with those, factory type stuff dosent need it to work.
