E4OD shift kit recommendations
I am looking into a shift improver kit and seen they have a mechanical one and a electronic one for the E4OD trans. All I want is a firmer shift, don't need it to bark second gear but don't want it sounding like it goes into neutral then the next gear either. Just wondered what you guys would recommend using, mine is a 91 in a F-250...Thanks
plowboy34- Posts : 223
Re: E4OD shift kit recommendations
Here is some good stuff that works well from sonnax.
http://www.sonnax.com/parts/2109
http://www.sonnax.com/parts/2107
http://www.sonnax.com/parts/2742
http://www.sonnax.com/parts/2110
whitefield- Posts : 2244
I have read the Punisher valve bodies are the best way to go with a E4OD.
http://www.fullsizebronco.com/forum/23-technical-write-ups/204088-punisher-valve-body-install.html
BigBlockRanger- Posts : 1260
I have never heard of Sonnax or punisher so this is some interesting reading...thanks guys
I Just mod the accumulator bodys, dont do it through the electrical side its hard on the pump.
☝️️☝️️ couldn't agree more! Jon did my valvebody 5 years ago and I couldn't be anymore happier. Best shifting E4od I've ever had!
61coon- Posts : 1824
Is there somewhere I can read on this....definitely interested
plowboy34 wrote:Is there somewhere I can read on this....definitely interested
The parts I listed is for the accumulator modification .
plowboy34 wrote:I have never heard of Sonnax or punisher so this is some interesting reading...thanks guys
Here is some good info!
http://powerstrokearmy.com/forums/showthread.php?t=20642&showall=1
Kobelco likes this post
» E4OD 3rd to OD shift lag
» FORD / MERCURY C-6 Floor shift axle / shift lever
» E4OD w/ a 545 anyone?
» C-4 VS TH400?
» ford overdrives
» C-4 VS TH400?
» ford overdrives
