Thanks Keith Fulp
Thanks Keith Fulp Empty Thanks Keith Fulp
Post  Doug Rahn December 4th 2016, 10:46 am
I want to give a shout out to Keith for some parts he made for me. He's made some stuff for me before to use on my Econoline project from a CAD drawing I sent him and as always, top quality. This time I had him make me some exhaust port covers for some work I'll be doing soon on my Mustang. In the past I have always used good ol' reliable Duct tape but if it stays on there for any length of time you end up cleaning off the residue and then there was the chance of a puncture and getting debris in the ports. Thanks again Keith!
Thanks Keith Fulp Exhaust%20Port%20Covers_zpsn9vtb22k
Thanks Keith Fulp Empty Re: Thanks Keith Fulp
Post  Lem Evans December 4th 2016, 11:50 am
I like dat.
Post  SandHillsHillbilly December 4th 2016, 3:31 pm
Those block off plates look great. Glad to see someone making them. Now we need a matching 4150 and 4500 flange block offs.
Hey Keith needs to autograph them in the fancy cnc mill. Signature Edition
SandHillsHillbilly
SandHillsHillbilly
Post  billandlori December 4th 2016, 4:34 pm
Fancy!! Cool
One of those things you didn't know you need till you see em, hey, I think I need a set of those!!
Bill
Post  QtrWarrior December 4th 2016, 4:45 pm
Working on the Mustang ?? Shocked
QtrWarrior
QtrWarrior
Post  Doug Rahn December 4th 2016, 5:21 pm
QtrWarrior wrote:Working on the Mustang ?? Shocked
Yep! Plan is to bring it back to my shop next weekend.
Post  res0rli9 December 4th 2016, 6:08 pm
They look Brassy
Post  Lem Evans December 4th 2016, 7:18 pm
res0rli9 wrote:They look Brassy
Gold....solid gold!
Post  Doug Rahn December 4th 2016, 7:42 pm
Lighting in my kitchen. They 1/4" aluminum plate.
Post  Doug Rahn December 4th 2016, 7:44 pm
Gold....solid gold!
Boy if they were, I ripped Keith off and there ain't no way he's gettin' them back, hahaha!
Post  Lem Evans December 4th 2016, 7:46 pm
Did he oring them?
Post  Doug Rahn December 4th 2016, 7:48 pm
Lem Evans wrote:Did he oring them?
No sir, but that is a good idea, although it would raise the cost.
Post  Doug Rahn December 4th 2016, 8:01 pm
Lem, what I did think of trying for a good seal was to etch the inside surface and apply some sealer then bolt them down lightly to a known flat surface with some Pam sprayed on it. Maybe leave about a 1/32" or 1/16" thick form in place gasket. Oh, I forgot to add that I did order some Spade Head Thumb screws with a flange for quick installation and removal without using a wrench.
Post  SandHillsHillbilly December 4th 2016, 8:09 pm
Why not some closed cell  foam attached to plates with spray adhesive? Trim outside after mounting foam on plates.
SandHillsHillbilly
SandHillsHillbilly
Post  Doug Rahn December 4th 2016, 8:11 pm
SandHillsHillbilly wrote:Why not some closed cell  foam attached to plates with spray adhesive? Trim outside after mounting foam on plates.
That will work too, another good idea.
Post  SandHillsHillbilly December 4th 2016, 8:12 pm
Make sure it is closed cell foam because open cell absorbs moisture with temp changes.
SandHillsHillbilly
SandHillsHillbilly
Post  Doug Rahn December 4th 2016, 8:17 pm
SandHillsHillbilly wrote:Make sure it is closed cell foam because open cell absorbs moisture with temp changes.
Great idea and I already found the perfect stuff on McMaster Carr.
Post  SandHillsHillbilly December 4th 2016, 8:24 pm
Y'all going to think I have gone crazy here.
You need a pair of panty hose color and size don't. Cut the legs off at the crotch.
Fill each leg with half a tub of this:
https://www.amazon.com/Gallon-Orange-Premium-Desiccant-Indicating/dp/B01I5Y9H6A
Tie a knot to close the legs off.
Place one leg in the oil pan and the other in the lifter valley or carb plenum. Seal it up.
If you open it later and find the crystals have changed color. Put panty hose legs in the microwave for 3-5 minutes to drive out moisture. Color should change back.Ready to reuse over and over.
Now it is up to you on explaining to wife or gf why you are playing with panty hose.
Updated link
Last edited by SandHillsHillbilly on December 4th 2016, 8:42 pm; edited 2 times in total
SandHillsHillbilly
SandHillsHillbilly
Post  SandHillsHillbilly December 4th 2016, 8:25 pm
Please share link.
SandHillsHillbilly
SandHillsHillbilly
Post  Doug Rahn December 4th 2016, 8:31 pm
SandHillsHillbilly wrote:Y'all going to think I have gone crazy here.
https://www.amazon.com/DampRid-FG50T-Hi-Capacity-Moisture-Absorber/dp/B0029EGUNG/
Okayyyyyyy! But just to be clear, I didn't have these made to keep moisture out, they are to keep debri out when I fabricate headers in the car one tube at a time.
https://www.mcmaster.com/#standard-foam-sheets/=15btse5
