BBF parts
TOPHER1
BBF parts Empty BBF parts
Post  TOPHER1 December 6th 2016, 6:23 pm
***SOLD**** Eddy heads 96CC with valves 2.25 int 1.76 exh flat tapped springs (need to be assmbled) comes with studs/Guide plates/rocker studs ported by (MADD Porter) supported 730+ HP to the ground ***SOLD****
***SOLD**** Accusump oil accumulator with electric pressure valve  ***SOLD****
***SOLD**** Kasse oil pump with studs used (going external pump) ***SOLD****
Offenhauser port-O-sonic 4500 flange have adapter to 4150, drilled ports for injection but currently plugged off $200
Offenhauser tunnel ram setup for Injections but could easily have a dual 4500 plate welded on it for carbs. $250
Cleaning out garage.. All parts are plus shipping and best reasonable offers.
PM if you need pictures
Thanks for looking
Chris (AKA TOPHER)
Last edited by TOPHER1 on January 1st 2017, 9:43 pm; edited 7 times in total (Reason for editing : updated information)
TOPHER1
BBF parts Empty Re: BBF parts
Post  Mike R December 6th 2016, 11:41 pm
Interested in the Kaase oil pump. Is it front or rear sump?
BBF parts Empty Oil pump
Post  TOPHER1 December 7th 2016, 7:11 am
Rear sump.
TOPHER1
Post  fastashley December 7th 2016, 8:31 am
I'm looking for an Enderle hat. Could you send me a few pics?
Thanks. Caleb 989-289-4379
fastashley
BBF parts Empty Hat pictures
Post  TOPHER1 December 7th 2016, 10:41 am
Caleb,
I will get pictures of everything I have associated with the hat. I just replaced O-rings in the metering block this season. I will text them to the number provided.
Chris
TOPHER1
Post  t-bird racer December 7th 2016, 12:02 pm
Is the intake a 950 or Dommy flange?  Where in MD?
t-bird racer
t-bird racer
BBF parts Empty intake
Post  TOPHER1 December 7th 2016, 12:55 pm
It is a 4500 Dominator flange.. I am in Reisterstown MD 21136
TOPHER1
Post  TOPHER1 December 7th 2016, 12:56 pm
I believe I have 4150 to Dominator (4500) adaptor will check and get back with you..
TOPHER1
BBF parts Empty Port-O-sonic
Post  TOPHER1 December 7th 2016, 5:29 pm
I have found the 4150 to 4500 adapter for the port-O-sonic intake price stays the same.
***** Also made some corrections/addition to original add*****
Heads have 1.76 exh valves heads flowed enough to push my 2850 mustang to 9.20 at 145
Have included return lines for Hat injection to tank same price.
Will get pictures if anyone else is interested.
TOPHER1
Post  Mike R December 7th 2016, 7:50 pm
You have a PM
BBF parts Empty Heads
Post  TOPHER1 December 7th 2016, 8:48 pm
PM replied
TOPHER1
BBF parts Empty Injection
Post  TOPHER1 December 9th 2016, 11:50 am
Injections system sold. Payment received Thank you fastashley
TOPHER1
Post  nuclearcobra December 12th 2016, 9:57 am
Reisterstown huh ,Haven't been there in years , Ya ever deal with John Spindler at Spindler Machine ?
nuclearcobra
nuclearcobra
Post  TOPHER1 December 12th 2016, 2:02 pm
No sir have never had any dealing with John Spindler. Is this someone I should meet or work with on BBF motors?
Did a quick google search and turned up nothing on Spindler Machine.
TOPHER1
Post  nuclearcobra December 12th 2016, 8:09 pm
Not a ford man totally just a great Machinist all around.
nuclearcobra
nuclearcobra
BBF parts Empty HEADS SOLD... Accusump Accumulator SOLD
Post  TOPHER1 December 17th 2016, 10:37 pm
Heads SOLD
TOPHER1
Post  Tore December 27th 2016, 11:56 am
You have a PM
Tore
Tore
Tore
BBF parts Empty OIL pump SOLD
Post  TOPHER1 December 29th 2016, 6:11 pm
Kasse OIL PUMP ***SOLD****
TOPHER1
