Marine Cam Driven Water Pump cover
Daytonatunnel
I'm trying to research and maybe locate a cover like the one pictured below. Any ideas, or is this a wild goose chase ? Thanks for any help.
Daytonatunnel- Posts : 36
Re: Marine Cam Driven Water Pump cover
Paul Kane might have something
I have one but it has a BB Chevy front seal.
Scott Foxwell- Posts : 419
There was a Dentist in gig harbor that had a bunch cast up for a bbf. Stan Johnson (Ford Powertrain Applications) might know how to get ahold of him. He is in Puyallup.
Darrin Gorham- Posts : 180
Scott Foxwell wrote:I have one but it has a BB Chevy front seal.
I had one of the Nicson marine covers.....I had it bored for the bbc seal in the front ....still could put the bbf seal at the back.
That was clever.Lem Evans wrote:Scott Foxwell wrote:I have one but it has a BB Chevy front seal.
I've looked at Paul's piece. It won't work for me, I want to retain my mech fuel pump. From what I've read, his may be able to do so with modifications. The pictured part looks as though it has provisions for a mech pump. It's what I'm after, clean and simple.
Darrin Gorham wrote:There was a Dentist in gig harbor that had a bunch cast up for a bbf. Stan Johnson (Ford Powertrain Applications) might know how to get ahold of him. He is in Puyallup.
Thanks for the tip, I'll try to find him
Daytonatunnel wrote:I've looked at Paul's piece. It won't work for me, I want to retain my mech fuel pump. From what I've read, his may be able to do so with modifications. The pictured part looks as though it has provisions for a mech pump. It's what I'm after, clean and simple.
I have one of Paul's covers and it has a cover that will let you use your pump.
I used it with an Enderle pump on my small motor..
QtrWarrior- Posts : 2699
QtrWarrior wrote:Daytonatunnel wrote:I've looked at Paul's piece. It won't work for me, I want to retain my mech fuel pump. From what I've read, his may be able to do so with modifications. The pictured part looks as though it has provisions for a mech pump. It's what I'm after, clean and simple.
That's encouraging, I thought I read it "may" work. Thanks for the info
» Water pump cover tapped
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» Belt Driven Oil Pump (Non dry sump)
» fuel pump 600 hp give or take .. best bang for the buck
» Switched from mech water pump to Moroso electric water pump
