Dry sump and Enderle mandrel
Dry sump and Enderle mandrel Empty Dry sump and Enderle mandrel
Post  fastashley December 21st 2016, 7:57 am
Switching to Enderle injection and dry sump. The Enderle pump is belt driven. Is there a mandrel set up that anyone recommends or has used themselves?
Crank is a Callies Boss snout. Will probably use Inovators West dampner.
fastashley
Dry sump and Enderle mandrel Empty Re: Dry sump and Enderle mandrel
Post  cool40 December 21st 2016, 10:55 pm
What oil pump do you have? I mounted the fuel pump on back of my oil pump so I only run one belt. If you have room for it I'd recommend going this route.
Post  cool40 December 21st 2016, 11:02 pm
Dry sump and Enderle mandrel Drysump003 found a pic
Post  Curt December 22nd 2016, 5:11 pm
I use the Innovators West and a Peterson Mandrel.
Dry sump and Enderle mandrel Newbuild12
Dry sump and Enderle mandrel Newbuild13
Post  fastashley December 28th 2016, 1:21 pm
Thanks for the info and pics. This is a big help. I'll see if I can do this with my pump
fastashley
Post  dfree383 December 28th 2016, 1:23 pm
Curt, you wouldn't happen to have the part numbers for the pieces you used?
Post  Lem Evans December 28th 2016, 1:48 pm
dfree383 wrote:Curt, you wouldn't happen to have the part numbers for the pieces you used?
I have that info.
Post  Curt December 29th 2016, 11:22 am
My parts supplier does. Very Happy
