Running a windage tray and oil pan baffel?
I am mounting a canton windage tray to my 429. I also have a oil pan with a oil baffle built in. Do I run both?
Please explain the reasons?
Thank you!
Bob
Tucson
Thank you!
Bob
Tucson
75truck- Posts : 102
Re: Running a windage tray and oil pan baffel?
Yes, run both. The windage tray helps keep unwanted oil from whipping up onto the crank and rods.
The baffle in the oil pan, if I'm understanding this correctly, is to trap oil around the pick up tube and keep it submerged in oil for when the vehicle is accelerating, braking, and cornering.
BBFTorino- Posts : 999
» Does a high volume oil pump necessitate a high volume oilpan?
» Windage tray
» Windage Tray
» windage tray
» Is the Mildon Windage tray Preferred over the Canton screen type one?
» Windage tray
» Windage Tray
» windage tray
