7/16 grade 8 cam bolt fine thread ?
whitefield
7/16 grade 8 cam bolt fine thread ? Empty 7/16 grade 8 cam bolt fine thread ?
Post  whitefield February 17th 2017, 4:18 pm
I was wondering what you guys torque your cam gear bolt to ? bullet solid roller cam with 7/16 x 20 fine thread grade 8. Thanks
whitefield
whitefield
7/16 grade 8 cam bolt fine thread ? Empty Re: 7/16 grade 8 cam bolt fine thread ?
Post  Scott Foxwell February 17th 2017, 4:58 pm
Dry, plated, grade 8 7/16-20 bolt is 58#. I'd say with a little oil 50-55 is plenty.
Post  rmcomprandy February 17th 2017, 9:39 pm
I normally use an alloy rod bolt which torques to 80 pounds.  "Double Pinning" an aggressive roller cam can use less.
Post  whitefield February 17th 2017, 9:54 pm
It is single pin. I went 60ftlbs with red loc tite . Should I go 80 ftlbs ?
whitefield
whitefield
Post  FalconEh February 17th 2017, 10:36 pm
whitefield wrote:It is single pin. I went 60ftlbs with red loc tite . Should I go 80 ftlbs ?
Have you used "red loc-tite" before on a cam and removed? I have found that red loc-tite usually lays a hurt on the fastener or the thread when removed, I usually use the blue, talking the color of the liquid sealer not the tube it comes in.
Post  whitefield February 17th 2017, 10:55 pm
Yeah I use loc tite on a,lot of fasteners. I have a loc tite rep that comes and talkes with my students. I take a little butane torch and heat it up and it comes right out.
whitefield
whitefield
Post  FalconEh February 17th 2017, 11:37 pm
Thanks Whitey, I have pulled up a desk...good tip.
Post  IDT-572 February 21st 2017, 10:20 pm
A good thick flat washer is a must also. A chevy harmonic balancer washer works great.
I use a grade 10 SHCS torqued to 75 ft lbs.
Post  Lem Evans February 22nd 2017, 10:48 am
"A chevy harmonic balancer washer works great."
SBC
Post  rmcomprandy February 22nd 2017, 12:11 pm
Lem Evans wrote:"A chevy harmonic balancer washer works great."
SBC
I buy 5 at a time ... and use the ARP hardened alloy, .275" thick washer #200-8717.
The ones directly from Chevrolet and regular parts houses are not hardened but, do work well most of the time.
Post  Lem Evans February 22nd 2017, 12:58 pm
I get'em a dozen at a time from an outfit in Cali .312" thick looks like this:
7/16 grade 8 cam bolt fine thread ? DG547002Small
Post  norm February 22nd 2017, 9:49 pm
I got some here-
https://www.mcmaster.com/#hardened-washers/=16h091d
norm
norm
