Cam
Cam
Looking to upgrade my 552 I'm taking the dish pistons out and putting flat tops in it while it's apart I'm going to have some cleanup work done on the heads they are aluminum scj heads should flow close to 400 when they're done compression is 13.5 is there an off the shelf cam that yall like or just go custom car will be a bracket rig
fordmonsta- Posts : 236
Re: Cam
If they are getting ported then I would get the flowed. Knowing the engine combination and flow numbers will give you the info need to get the correct camshaft.
Straubtech- Posts : 293
Re: Cam
fordmonsta wrote:Looking to upgrade my 552 I'm taking the dish pistons out and putting flat tops in it while it's apart I'm going to have some cleanup work done on the heads they are aluminum scj heads should flow close to 400 when they're done compression is 13.5 is there an off the shelf cam that yall like or just go custom car will be a bracket rig
For a big Ford aluminum SCJ head I'd doubt that there is any thing "off the shelf" that would be real good. Most of those cams were done before those heads were even born.
