2001 7.3 engine harness
i'm putting together a 2001 F350 cclb lariat 6 speed, someone half a$$ spliced valve cover harness pigtails on. i'm having absolutely no luck finding one to replace it. ford part number 1C3Z-12A581-GAB. i'm told its 2001 6 speed only. any help is appreciated
phil1206- Posts : 71
Re: 2001 7.3 engine harness
Is this what you're looking for? http://www.dieselorings.com/1999-2003-ford-7-3l/engine-uvc-and-electrical/16-015-valve-cover-gasket-plug-harness-repair-kit.html
those are what someone spliced on to the harness. i'm trying to find the entire engine harness
Call these guys at Tasca
http://www.ebay.com/itm/NEW-OEM-MAIN-ENGINE-WIRING-HARNESS-FORD-EXCURSION-F250-F350-F450-F550-SD-7-3L-/222070632122?hash=item33b470eeba:g:0~EAAOSwLpdW~TFe&vxp=mtr
I should have mentioned the harness my vin calls for was discontinued. thanks for the link Doug, I called but it was a swing and a miss
Looks like your only options are to repair what they did or one from a salvage yard. In the past I've had pretty good luck with this website when I couldn't find it locally. http://www.junkyarddog.com/
thanks Doug i'll check them out. i repaired what they done but i'm not happy with how it looks I've took the harness to a few electrical shops and they told me my repair was good enuff and i'm to picky
» 1974 Cougar 460 Engine Bay Wiring Harness
» fuel pump, 5 point harness, trans sheild
» RJS 4 pt harness
» Wiring harness
» PEAK 5 pt harness
» RJS 4 pt harness
» Wiring harness
» PEAK 5 pt harness
