C-460 heads
C-460 heads
Are there any stud girdles available for C-460 heads? Seems like one of the bigger expenses to setting them up is the shaft mounted rocker arms. At what point would you not use stud girdles (if available) due to spring open pressure ?
Thanks,
Sheldon G.
Thanks,
Sheldon G.
STR-LGL-70- Posts : 223
Re: C-460 heads
STR-LGL-70 wrote:Are there any stud girdles available for C-460 heads? Seems like one of the bigger expenses to setting them up is the shaft mounted rocker arms. At what point would you not use stud girdles (if available) due to spring open pressure ?
Thanks,
Sheldon G.
There is no way to use studs for rocker gear on C460 heads. So, that means that a "stud girdle" is not even applicable.
Re: C-460 heads
Thanks for the replies.
Sheldon G.
Sheldon G.
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» A429 Heads VS Dove-c Heads
