D6VE CODE =
D6VE CODE =
I have a 1969 XL 500 that the vin indicates a 429 4v. However, I was told that since this car has an electronic ignition it is most likely a later model 460. Can anyone help with this?
Thanks.
Thanks.
1969XL500- Posts : 2
Re: D6VE CODE =
1969XL500 wrote:I have a 1969 XL 500 that the vin indicates a 429 4v. However, I was told that since this car has an electronic ignition it is most likely a later model 460. Can anyone help with this?
Thanks.
A D6VE casting number indicates that the part in question was either designed or had a design change from the original print in the year 1976 for a regular passenger car application.
"D" indicates the decade - "6" is the year - "V" is the application - "E" is regular production
Re: D6VE CODE =
But the same numbers do usually continue over several years
Re: D6VE CODE =
rmcomprandy wrote:1969XL500 wrote:I have a 1969 XL 500 that the vin indicates a 429 4v. However, I was told that since this car has an electronic ignition it is most likely a later model 460. Can anyone help with this?
Thanks.
If that code on the intake manifold is from a 76 model, could it fit on a '69 429?
Re: D6VE CODE =
Yes the intake I'll interchange, but the carb and emissions stuff will be different and could have different patterns
Re: D6VE CODE =
Thanks.
Plug a spark plug and stick a bore scope in it and see what the top of the pistons look like. Smog 460's have a big Dish.
supervel45- Posts : 4499
» D6VE RODS?
» Factory D6VE-AA 460 Rods
» 460 rods D6VE ....BRAND in box arp hardware
» Factory Rods for sale, (7) F6TE & (8) D6VE
» N code 429
» N code 429
