460 WITH BLOWER AND DUELCARBS
6t6mustang
Flipncrazy
Hi all looking into building a 460 blower engine with roller cam for a jet boat. I'm looking for ideas on parts pistons(compression) but mostly I just want a good dependable blower. its not for racing just weekend warior stuff but I would like it to be dependable as best it can so ill need ideas ect on all this and ill need parts eventualy and any cam ideas is welcome also my plan is all hp I can get at 5500 rpm .going with alum CJ heads I think .
Flipncrazy- Posts : 2
Re: 460 WITH BLOWER AND DUELCARBS
Cant go wrong with the blower shop units..
6t6mustang- Posts : 93
Where do you live at?
jasonf- BBF CONTRIBUTOR
The Blower Shop, BDS, Littlefield are the three I would be looking at. TBS and BDS will have complete kits you can look at. Blower size will depend on how much power you want to make but for 460ci @ 5500, you can make 750+hp on pump gas with less than 10# boost pretty easily with an 871 and a pair of 850's. 700 hp observed, not corrected, will turn a AA impeller about 5700 rpm. I would go with a hydraulic roller and you'll need flow numbers from the heads. Compression; I would keep around 8.0:1. If you can afford an intercooler, that would help, but on the BB Ford it makes a very tall package. Make sure the engine is built with marine use in mind. You want a little more piston to wall clearance and a little more valve guide clearance, and you'll want to use good quality parts throughout. Stock crank may be OK, but forged would certainly be better. H beam rods, good pistons and rings (no Hellfires) and good valve train with quality valves and rockers. The most important thing will be the machine work and block finishing.Flipncrazy wrote:Hi all looking into building a 460 blower engine with roller cam for a jet boat. I'm looking for ideas on parts pistons(compression) but mostly I just want a good dependable blower. its not for racing just weekend warior stuff but I would like it to be dependable as best it can so ill need ideas ect on all this and ill need parts eventualy and any cam ideas is welcome also my plan is all hp I can get at 5500 rpm .going with alum CJ heads I think .
Scott Foxwell- Posts : 419
see, there is good tech in here..
great advice
ill be moving to az where the engine will be built and ran im definatly impressed at the replys esp scot tvm ill definatly follow that advice especialy on the crank. will post pics as i start from the block .lord send me money lol
What impeller and housing ...?
The SMALLEST unit to even consider using is an aftermarket 8-71 with any engine of 460 cubes or bigger.
No matter what crank you use, have it machined for dual keyways and same with your balancer/hub.
A blower has a way of tearing up the crank snout when all that stuff works its way loose from all the tugging, yanking, and pulling on it!!
BBFTorino- Posts : 999
» 871 Blower Advice
» Roots Blowers
» blower
» BBF 8-71 blower, Bif Uggly injector, Intake, spacer SOLD SOLD SOLD THANKS
» FS: New Vortech V4X "Race H" supercharger
» Roots Blowers
» blower
