Cam duration @.200" lift
JBR-3
Cam duration @.200" lift Empty Cam duration @.200" lift
Post  JBR-3 April 2nd 2017, 7:49 pm
Last edited by JBR-3 on September 20th 2020, 12:27 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Cam duration @.200" lift Empty Re: Cam duration @.200" lift
Post  rmcomprandy April 2nd 2017, 8:19 pm
There is no rule of thumb ...
that @.200" number can change 15 degrees or more for the same duration @.050" depending upon the aggressiveness of the particular lobe profile.
Post  Straubtech April 4th 2017, 12:25 pm
rmcomprandy wrote:There is no rule of thumb ...
Agreed. This one reason I tell customers that .050" numbers tell you nothing about the camshaft. It is a reference point selected to "Market" camshafts with. Case in point I have 2 lobes that are .312 and .315 Lobe lift and at .050 they are both 230. Not much difference. Well at .200 there is 14 degrees of difference. One would look at that in .050" numbers and say the one cam is much larger. Well in this case one is much larger. The lobe area is what you need to know. The whole picture.
Straubtech
Post  JBR-3 April 4th 2017, 5:18 pm
JBR-3
Post  68galaxie April 4th 2017, 5:49 pm
This doesn't apply only to roller lobes, it applies to all lobe types.
The 0.200" duration doesn't tell all about a camshaft either.
68galaxie
68galaxie
Post  IDT-572 April 5th 2017, 12:06 pm
.006 numbers play too.............
Post  Straubtech April 5th 2017, 12:22 pm
It all matters, but you have to think like an advertiser: what info do we need to sell cams.....needs to be short and sweet. If you put the entire lobe area on there checked at .020" increments you could get 1 lobe per page.
Straubtech
Post  Lem Evans April 5th 2017, 10:15 pm
.007" do too.
