Rocker arm?
Mudbogger
Rocker arm? Empty Rocker arm?
Post  Mudbogger May 11th 2017, 11:46 am
What rocker arm would be best for for a .900 lift cam and 950# open spring pressure in an iron head, i have a jomar girdle already, i was looking at a crower steel roller rocker arm max rpm maybe 7500
Mudbogger
Rocker arm? Empty Re: Rocker arm?
Post  Lem Evans May 11th 2017, 11:49 am
The best stud mounted rocker would be the Crower S.S.
Post  Mudbogger May 11th 2017, 11:53 am
Thanks. If a shaft mount system was in the budget for it what would you recommend ? Jessel?
Mudbogger
Post  gt350hr May 11th 2017, 11:58 am
Nothing wrong with T&D in my experience. Crower is THE best SS rocker out there.
gt350hr
Post  Scott Foxwell May 11th 2017, 3:01 pm
Mudbogger wrote:Thanks. If a shaft mount system was in the budget for it what would you recommend ? Jessel?
Not Jesel. T&D would be my only choice.
Post  Mudbogger May 11th 2017, 3:02 pm
Mudbogger
Post  BOSS 429 May 11th 2017, 5:28 pm
Mudbogger wrote:What rocker arm would be best for for a .900 lift cam and 950#  open spring pressure in an iron head, i have a jomar girdle already, i was looking at a crower steel roller rocker arm max rpm maybe 7500
Harland  Sharp for stud mounted, or jessel, or WW for shafts
Post  Mudbogger May 12th 2017, 2:59 am
I seen Harlan Sharp has new HD rocker arm for big lifts and high spring pressure
Mudbogger
Post  BOSS 429 May 12th 2017, 10:40 am
they have for quite a while. work great , and are lite compared to SS stuff @ any rpm
Post  Mudbogger May 12th 2017, 10:59 am
Price seemed reasonable to , will have to look into them some more
Mudbogger
Post  Lem Evans May 12th 2017, 11:17 am
Much of the Crower S.S. wt. is in the big ass shaft......which does not rotate.
Post  Paul Kane May 12th 2017, 2:18 pm
As far as those which are currently in production and readily available, the Crower stud rockers--both aluminum and steel--have the best design geometry for their originally-intended cylinder head applications.
Given your noted lift and presumed spring pressures, I'd recommend the Crower steel.
Post  Mudbogger May 12th 2017, 5:41 pm
Thanks for the replies, we'll be using Pac 1248 springs.One more question, builder said bushed roller lifters, any suggestions on which ones to use thanks
Mudbogger
