spark plugs for 466 with 14 to 1 comp
Hi guys I am looking for a spark plug heat range for my 466 14 to 1 drag car. It has iron cobra jet heads and flat tappet cam and I am looking for an NGK plug heat range number. I use 110 octane in this and the plugs in it now are very old autolite's. I just got it running for this year and it seems to have a little miss so gotta start somewhere.
57ford custom- Posts : 107
Re: spark plugs for 466 with 14 to 1 comp
57ford custom wrote:Hi guys I am looking for a spark plug heat range for my 466 14 to 1 drag car. It has iron cobra jet heads and flat tappet cam and I am looking for an NGK plug heat range number. I use 110 octane in this and the plugs in it now are very old autolite's. I just got it running for this year and it seems to have a little miss so gotta start somewhere.
IF it is kept below 180 degrees, A 7 or 8 depending upon if it is driving or racing.
The 8 is colder on NGK plugs. The colder the better with 14-1 on 110 octane.
gt350hr- Posts : 662
Thank you I will order a set tomorrow and start with number 8's
I'm guessing if his operating temp gets above 180 he would need an even colder heat range?
460bronco- Posts : 364
Now where can I find a set of these
My local Autozone is no help so far.
» spark plugs and e85
» NGK spark plugs
» spark plugs
» What spark plugs for A-429's
» Spark plugs for 429
» NGK spark plugs
» spark plugs
