Header install into 75 ford truck
Header install into 75 ford truck Empty Header install into 75 ford truck
Post  75truck May 27th 2017, 10:20 pm
Installing Headman headers into my 75 Ford f250 Super Cab with a 429.
Header install into 75 ford truck IMG_1081_zpsnsemkee9
What is the best way to install?
Header install into 75 ford truck IMG_1080_zpssa81ijkl
With headers installed on heads while installing engine and tranny (tranny is a ZF-5)
Or
After engine is installed?
Also what are best gaskets and bolts to use?
Bob
Tucson
75truck
Header install into 75 ford truck Empty Re: Header install into 75 ford truck
Post  BBFTorino May 27th 2017, 11:39 pm
If the engine is out of the truck, lay the headers in place. Put a piece of wire or something to hold them in the area when you're dropping the motor in.
