novi 2000 mount and pulley setup
hey guys, looking for some input...
I have a 460 still using factory alternator and water pump pulleys. I picked up a paxton novi 2000 that I plan to put on. Ive looked around all over but havent seen any solid info on this. It seems obvious that nobody makes a bolt on bracket, Im not worried about fabbing up mounts if I have to, but if anyone has done this setup before, Id love to see pics, hear advice, other brackets that fit with mods (BBC?, SBF?), lessons learned etc...
The part Im really curious about is how to setup the pulleys, is there a crank pulley for the paxton that goes on front of the factory crank pulley setup, or should I/will I need to swap the factory stuff all to a serpentine belt or something like that.
curious to hear thoughts and would love to see any pics if someone else has done this.
thanks!
scott
thanks!
scott
swoodman23- Posts : 15
Re: novi 2000 mount and pulley setup
quick update - nevermind the pulley question above. After continued poking around, found some things at superchargersonline that look like what I'll need.
still curious if anyone has setup like this and has pics or any input.
thanks!
thanks!
what about using a serpentine set from a late 460 and doing some creative belt work
83Capri- Posts : 58
thanks 83capri... can investigate that also if I need...
» WTB: Complete Alt/PS/York AC bracket pulley setup
» crank pulley and alternator/fan/pulley options?
» NEW Paxton NOVI 2200 supercharger
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» Acc. Pulley set
» Acc. Pulley set
