mud truck shock???
mud truck shock??? Empty mud truck shock???
Post  racinghabbit May 31st 2017, 11:22 am
What are you guys running for shocks.? I do straight line mud drags....
racinghabbit
racinghabbit
mud truck shock??? Empty Re: mud truck shock???
Post  68formalGT May 31st 2017, 7:16 pm
Afco coil overs front and rear
Post  racinghabbit June 5th 2017, 10:01 am
I am looking for a stock style replacement that has be valved for drag racing
racinghabbit
racinghabbit
Post  FORDMUD June 5th 2017, 4:09 pm
Before I changed classes, I ran the competition engineering adjustable shocks. 90/10 on the front and 50/50 in the back. My truck had about 1" of lift. I remember the bolts and bushings being different, but It worked out pretty good.
FORDMUD
FORDMUD
Post  68formalGT June 5th 2017, 11:23 pm
FORDMUD wrote:Before I changed classes, I ran the competition engineering adjustable shocks. 90/10 on the front and 50/50 in the back. My truck had about 1" of lift. I remember the bolts and bushings being different, but It worked out pretty good.
I did the exact same thing but with Afcos.
Post  racinghabbit June 6th 2017, 5:10 pm
I took a gamble on Bilstein shocks 5125 series found firm front soft rear, there tech was very helpful and I should be able to use my stock mounts. anything will be better than what I had..
racinghabbit
racinghabbit
Post  kjett June 22nd 2017, 9:18 am
I run a combination of flat track and hill and hole pits. Found the Fox 2.0 air shocks with the 1.25" shafts worked very well. My stock springs were there to keep me in class rules as well as act as overloads for the bumps. The fox shocks held the truck up and if I removed them, everything would droop 3-4". Would have gone back to them, but I'm going full on 4 link and coilover on the new ride.
kjett
kjett
Post  pigs521bbf June 22nd 2017, 1:08 pm
anyone have part numbers for the shocks you guys are talking about?
pigs521bbf
Post  kjett June 22nd 2017, 2:56 pm
pigs521bbf wrote:anyone have part numbers for the shocks you guys are talking about?
I ran these in 12" travel front and 10" travel rears:
https://www.polyperformance.com/fox-2-0-air-shock
kjett
kjett
