Spark plug help 9.5:1 532 d3 iron heads,
Spark plug help 9.5:1 532 d3 iron heads,  Empty Spark plug help 9.5:1 532 d3 iron heads,
Post  TravisRice July 4th 2017, 7:58 am
Need a good starting point. Msd 6al box, duraspark distributor, 830holley vac carb, performer air gap intake, hydraulic roller camshaft ,headers, 4.3 crankshaft, 5 spd transmission, 4.10 rear gear, weekend street use only in a 67 ford f250 2wd truck. Won't be towing anything as it's a frame off resto mod.
Travis
Spark plug help 9.5:1 532 d3 iron heads,  Empty Re: Spark plug help 9.5:1 532 d3 iron heads,
Post  rmcomprandy July 4th 2017, 5:32 pm
For the street engines I build with those heads I use an Autolite AP24 but, the regular 24 should work.
Post  TravisRice July 4th 2017, 6:09 pm
Thanks Randy. I've never had an iron head pump gas motor and wondered about what plug and range with an msd ignition. Much appreciated.
Travis
