K-member clearancing Fox body for cast manifolds
I was wondering if any one has had experience using cast car manifolds in a fox body and having to clearance the k-member. passenger side manifold is resting on the k-frame at the flange, causing the drivers side to rub the steering shaft.
My question is - Should I just cut the stuff right out and not worry about it or should I try to reinforce it with a piece of tube? Third option switch to coil overs to reduce stress on the control arm and lower portions of the k-mamber
Thanks guys
Thanks guys
83Capri- Posts : 58
Re: K-member clearancing Fox body for cast manifolds
Factory k-member? If so, you could probably cut a "window" in it to give the room you need and be OK.
jbozzelle- Posts : 3705
» cast iron PI exhaust manifolds
» Removing cast iron exhaust manifolds.
» WTB: Fox body K member
» Fox body double hump trans X-member
» 1993 mustang GT body $1000.00 / 1991 mustang GT body $500.00
