HOLLEY HP ALPHA N BASE FUEL TUNE
Looking to see if anyone has a tune i can download from them, or even if someone could remote tune an "alpha n" base fuel setup into my holley hp ecu. Been having issues figuring out what to enter for lbs./hr based off TPS % .
SPECS ARE: Holley hp efi with custom mpfi. Msd 6al digital box combined with msd dist. Total timing set to 38degrees@2400rpm all in, and idle timing at 17degrees. BBF 466CUinch, TRW L2443 dome top pistons, 14.25:1 compression ratio, 75cc edelbrock performer rpm heads, rpm airgap intake, 1100cfm holley efi throttle body, solid mechanical roller cam specs comp cam magnum part #34-710-9 [5] grind #300A-R10
3800 rpm stall c6 trans full manual valve body, 205tcase, 5.38 gear ratio.
i want to run an alpha n tune in case of an 02 sensor failure to default to from my traditional speed density tune. Also currently running 112 fury fuel. even if someone has some close enough numbers to go off by i can dial it in thru datalogging and a few runs, thanks so much.
joeyschribar- Posts : 2
Re: HOLLEY HP ALPHA N BASE FUEL TUNE
Do you have some type of exhaust pipe after the collector and do you have any slip connections on the headers?
I am still a newbie with my hpefi but from talking to a friend that is a tuner you can't have any exhaust leaks for the O2 sensor to work properly. You also need some pipe after the collector to prevent air being sucked in the header on the exhaust pulses. Obviously that would be one benefit to the alfa N by eliminating the O2 readings.
jasonf- BBF CONTRIBUTOR
I have about 30" exhaust past the 02 sensor, which is mounted just a few inches past where each header collector meets to a single 3.5" dump out behind passenger seat. I am having problems dialing in a speed entity tune as well, switching out to an ntk wide band sensor as I currently run leaded fuel may of damaged the sensor
» Need a 950 holley base plate
» Holley tuning
» Holley Fuel Pumps, Fuel regulators,Earls AN fittings
» Holley HP 150 fuel pump
» blp telescoping holley fuel log
» Holley tuning
