pushrods for kaase p51 heads
Rickytx630
pushrods for kaase p51 heads Empty pushrods for kaase p51 heads
Post  Rickytx630 August 7th 2017, 5:34 pm
looking for pushrods for kaase p51 heads. block is factory 10.3 deck, using lunati roller lifters and scorpion 1.73 rockers. heads are out of the box and are not cut/milled to my knowledge. using felpro 1018 headgaskets. the push rods i have now are .100 over stock length and there too short. i really rather not pull it apart again, is there a part number that people are using or with a similar set up?
Rickytx630
pushrods for kaase p51 heads Empty Re: pushrods for kaase p51 heads
Post  69F100 August 7th 2017, 6:54 pm
You need to buy a pushrod checker to find the correct length of pushrod you will need.
Post  jbozzelle August 8th 2017, 9:18 am
Get a pushrod checker and some light springs and check to be sure. You should end up in the 9.100" int. / 9.300" exh. range depending on the rockers, lifter cup ht. and head milling.
I switched from the FRPP blue rockers to the Comp Ultra Pro Magnum XD and needed a slightly longer pushrod.
Check to be sure...
Post  Straubtech August 8th 2017, 1:36 pm
Rickytx630 wrote:looking for pushrods for kaase p51 heads. block is factory 10.3 deck, using lunati roller lifters and scorpion  1.73 rockers. heads are out of the box and are not cut/milled to my knowledge. using felpro 1018 headgaskets. the push rods i have now are .100 over stock length and there too short. i really rather not pull it apart again, is there a part number that people  are using or with a similar set up?
https://www.youtube.com/watch?v=o5is9BsH5OU
Straubtech
Post  away August 8th 2017, 3:56 pm
Use Cometic head gaskets! MLS
away
away
Post  rmcomprandy August 8th 2017, 7:34 pm
I'd make a bet that the people at Kaase's know what pushrod lengths will work with a stock short block type engine.
Stock length pushrods WILL be way to short.
