41 Ford mud skipper
41 Ford mud skipper Empty 41 Ford mud skipper
Post  IDIeselman August 11th 2017, 9:37 pm
Complete as you see it. 100 percent rust free and all steel with professional show winning paint.The grill and headlight bezels are Drake re-pops. Bearclaw door latches and the floor is custom built with heavier gauge steel the clear a C6 trans and offer scatter protection. Factory cab mount locations retained. Rear and side windows are poly, front is glass. Complete truck available turn key with 745 HP/641TQ iron headed 521 for $15,000. Located in ludington mi 49431. 79 bronco chassis, cut 35" Boggers, Detroit locked 9", Track-Lok Dana 44 both with chromoly shafts. 4.10 gear. Built reverse pattern manual C6, UCC 9" 4500 stall converter. NP 205 case. Cal-trac rear bars/ Rancho 5000's. Fox 2.0 90/10's up front. D9TE-AB 460 block, CNC ported/blended D00E-R Cobra Jet iron heads, forged Scat crank and H beam rods, Diamond piston, Lunati roller rockers, Jomar stud girdle, Trick flow intake with 1150 Dominator carb. Morose electric water pump. Built by R.M competition in Roseville michigan. Truck runs high 4's low 5's on top of 250' pits. It's a skipper not a Bogger. https://m.facebook.com/groups/675844779235736?view=permalink&id=892609604225918
IDIeselman
IDIeselman
