NEW HERE ,NEW CAR , NEW TO BBF PLEASE HELP
Gotgrowth
NEW HERE ,NEW CAR , NEW TO BBF PLEASE HELP  Empty NEW HERE ,NEW CAR , NEW TO BBF PLEASE HELP
Post  Gotgrowth August 14th 2017, 6:21 am
How's it going guys. First post here I'll try to make it short
I'm picking up a solid 69 fastback that needs a drivetrain. I also have a killer deal lined up on a basically brand new drivetrain
The drivetrain is as follows
472 stroker
dove heads ported to match
1100 carb
Dominator intake
Comp cam 736 lift solid roller
Knife edge crank billet
11:1 Manley pistons
700+ hp
Hugh Stevens c4 race tranny
This drivetrain was built to make power on the strip However I will be using it more for street use and a handful of track days a year
I need help on which cam and valve springs I should go with .reliability is important as well
The guy that has the motor also took it apart some to show potential buyers the condition. While doing that I was informed that the "oil guides " where the pushrods go into. were flipped (o shaped cutout exposed) this didn't cause issues while running and oil pressure was good (1500 miles and 2 passes). I just don't know if this could be something detrimental in the future when I buy it down the road. I was told they can be flipped and I will be fine. But id figure is ask here.
With the above info if anyone can recommend a good converter that would be appreciated.
Thanks in advance
Gotgrowth
NEW HERE ,NEW CAR , NEW TO BBF PLEASE HELP  Empty Re: NEW HERE ,NEW CAR , NEW TO BBF PLEASE HELP
Post  dfree383 August 14th 2017, 8:32 am
Please explain your engine a little more.
I'm thinking you've got some things mixed up a little.
Where you getting this engine? You building it new?
Post  supervel45 August 14th 2017, 8:32 am
Are you referring to guide plates?
Are you asking for torque converter brand recommendations or stall speed? If stall speed you need to settle on a cam first.
Welcome aboard by the way and sounds like a nice ride.
Post  Gotgrowth August 14th 2017, 8:38 am
The engine is listed on craigslist it is already built I have a picture of the part that he says is installed backwards but I'm trying to figure out how to upload it on this forum
Stall speed and brand reccomendations would be appreciated as I am new to automatics. The previous guy was running a 5000 stall which I was told is way too much for street use
Gotgrowth
Post  dfree383 August 14th 2017, 8:46 am
Gotgrowth wrote:The engine is listed on craigslist  it is already built  I have a picture of the part that he says is installed backwards but I'm trying to figure out how to upload it on this forum
I'd stay away from that engine, just the description has me on BS alert.
Post  Gotgrowth August 14th 2017, 8:49 am
He sent me pics of the engine broken down. Looks pretty clean Deal is really good. Maybe too good. Ugh. Lol
I started a thread over on 460ford.com with basically the same title in the engine build archive. Where I uploaded a pic if anyone is a member there
Gotgrowth
Post  rmcomprandy August 14th 2017, 9:55 am
A 472 STROKER ...? Offset ground production crankshaft ...?
What is the bore and stroke on that one ...?
Post  Gotgrowth August 14th 2017, 9:57 am
Not sure. Was a 460 block that's all I'm sure of
Gotgrowth
Post  5pointslow August 14th 2017, 10:11 am
rmcomprandy wrote:A 472 STROKER ...?  Offset ground production crankshaft ...?
x2 on that
my 472 is stock stroke and rod length .060 over
5pointslow
5pointslow
Post  supervel45 August 14th 2017, 10:31 am
I'd be careful on that deal, it does odd. Billet Crank? If you are paying for that I would verify, first.
Post  Gotgrowth August 14th 2017, 10:35 am
I just verified that the lifters are definitely a roller type lifter , How can I verify that the crank is billet. I can have the guy send me pictures if need be
Gotgrowth
Post  jasonf August 14th 2017, 1:14 pm
Gotgrowth wrote:I just verified that the lifters are definitely a roller type lifter ,   How can I verify that the crank is billet.  I can have the guy send me pictures if need be
The guy sounds full of BS as stated so why are you trying to justify this motor??
A 472 is not a stroker.
Nobody puts a $4000 billet crank in a stock engine.
And 700+ hspr with dove heads??
Assembled wrong by the person trying to sell it??
What sounds right about any of that to you??
Post  Gotgrowth August 14th 2017, 1:23 pm
The guy selling it is the shop that installed the engine and built the car for the owner. He wrapped the car up and bought another car that was done. and kept the drivetrain that's for sale The deal is for
Engine , built c4 trans , new aluminum radiator , ford 9 rear with moser axles. Headers and other parts. For 3k. But I will not be taking the rear or headers. So even if I get the motor with carb and trans and radiator for 2k. Even if the motor was "relatively stock". Wouldn't that still be a really good deal ?
UPDATE. owner of the shop just texted me and found out it's a stock crank and stock rods The owner of the car was lied to when he bought the motor that's why he pulled it apart to see cause he wasn't going to sell anything to somone if he didn't know for sure and put his shops reputation on the line
Gotgrowth
Post  BBFTorino August 15th 2017, 12:13 am
Walk away from it. Build a nice motor for yourself so you will know for sure what it contains.
Post  jeffgfg August 15th 2017, 10:31 am
I saw the pictures on the other site and one question comes to mind......If the builder of the engine installed the roller lifters wrong what else did he do wrong while assembling the engine??? Also a race prepped C-4 isn't the best trans to drive on the street behind a big block, For the type of driving you plan to do I think a C-6 would be better. As others have said walk away from this one and call some of the vendors on this site and have an engine built just for you. Just my 2 cents.
jeffgfg
