8 ignition coils
8 ignition coils
Last edited by JBR-3 on September 20th 2020, 1:22 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: 8 ignition coils
I think some of the big HP boosted cars are running systems that can also curve and play with timing on individual cylinders to even out the engine? I don't keep up with it though.
supervel45- Posts : 4498
JBR-3 wrote:Just curious if anyone has played with this on a BBF.
Here's a Mopar guy who is experimenting:
http://board.moparts.org/ubbthreads/ubbthreads.php/topics/2339347/1.html
Andy Finkbeiner is pretty sharp.
It seems the biggest hurdle is tying in to the ignition firing order to tell which cyl to fire.
Andy modified the distributor.
Controlling the spark curve is evidently done in a computer.
I have a street-rod customer with a 501 big block Ford using L92 GM truck coils and the MSD system for a carbureted LS engine.
He bolted an LS shutter wheel to the damper and fixed a pick-up behibd his pulleys and it works great.
I have 8 LS coils on my HPefi. If you google it there is some backyard methods out there from before the msd units were available.
jasonf- BBF CONTRIBUTOR
Below is the msd controller. You can buy a cam sensor from Price Motorsports and use a MSD crank trigger setup. I am not familiar with the msd unit but there are different types of crank trigger sensors so I would check with MSD for requirements in that department. I got my coils at Pull A Part from a Yukon.
http://www.streetmusclemag.com/tech-stories/engine/tech-carbureted-ls-engines-ignition-and-induction/
http://www.pricemotorsport.com/html/body_camshaft_synchronizer.html
Last edited by JBR-3 on September 20th 2020, 1:23 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
» Ignition Coils and Boxes?
» Ignition help.
» Per ignition / detonation - Need help
» Any ignition box better than MSD
» Ignition Box?
» Ignition help.
» Ignition Box?
