need help. sick ford.
Rickytx630
need help. sick ford. Empty need help. sick ford.
Post  Rickytx630 August 27th 2017, 2:57 pm
put the 514 back together and in the car, when to go fire it up and it would only turn over a few times and then pop out the exhaust, after screwing with the distributor a few times it will turn over a little more before it does it again, checked the gap on the crank trigger. was slight off, fix that and now it wants to pop through the carb. pulled #1 plug but it doesnt seem to be soaked, ive pretty much tried everything i can think of and just ran out of ideas, this rebuilds been nothing put problems, No
Rickytx630
need help. sick ford. Empty Re: need help. sick ford.
Post  BOSS 429 August 27th 2017, 6:41 pm
Rickytx630 wrote:put the 514 back together and in the car, when to go fire it up and it would only turn over a few times and then pop out the exhaust, after screwing with the distributor a few times it will turn over a little more before it does it again, checked the gap on the crank trigger. was slight off, fix that and now it wants to pop through the carb. pulled #1 plug but it doesnt seem to be soaked, ive pretty much tried everything i can think of and just ran out of ideas, this rebuilds been nothing put problems, No
should be moving it once you phase it it, did you phase it in?
Post  Rickytx630 August 28th 2017, 2:09 pm
i have. same way we have always done it. im also not getting any oil pressure. its the same pump the was in the motor before the rebuild and always had good pressure,
Rickytx630
Post  maverick August 28th 2017, 7:07 pm
If the engine isn't running, how do you know you have no oil pressure? Did you prime the oil pump before the distributor went in?
Post  FalconEh August 28th 2017, 8:09 pm
Admittedly, I once made the mistake of installing the wires on the cap clockwise, it wasn't happy and I knew better. Embarassed
Post  hienergy557 August 28th 2017, 10:11 pm
Check the roll pin in the dist gear.
hienergy557
hienergy557
Post  maverick August 29th 2017, 6:27 pm
hienergy557 wrote:Check the roll pin in the dist gear.
......and while the distributor is out, spin that oil pump with a drill. Wink
Post  TravisRice August 30th 2017, 7:51 pm
Valves adjusted too tight? Hanging open?
Post  tbirdmike September 1st 2017, 2:03 pm
Have you put a timing light on it while cranking to verify timing.
Quick way to tell if its a mile out.
tbirdmike
Post  Rickytx630 September 3rd 2017, 1:40 pm
hey sorry been awhile since i been able to get on, got the car running. not exactly sure what it is, ended up changing the oil pump as i had no pressure and wasnt taking a chance,
always prime my motors before i try to start them, this one had 60lbs no problem. dropped the distributor in and it fired up. locked timing at 28*
i did do another rocker adjustment as 3 were a little on the tight side. valve lash is set 28in and 30 exh.
only problem i have now is a sligt dead spot in the started. its out and being rebuild after 12 years of use.
Rickytx630
