Hydraulic roller lifters !
+14
rollercam1
pmrphil
68galaxie
Wayne Pearce
SandHillsHillbilly
torino501
SLord82
JBR-3
18 posters
Page 2 of 4 Previous  1, 2, 3, 4  Next
Hydraulic roller lifters ! - Page 2 Empty Re: Hydraulic roller lifters !
Post  BOSS 429 September 19th 2017, 6:30 pm
429 460 based engine NOT WORTH THE HASSLE to use hyd roller lifter/cam.
Post  Scott Foxwell September 19th 2017, 6:51 pm
BOSS 429 wrote:429 460 based engine NOT WORTH THE HASSLE  to use hyd roller lifter/cam.
Why don't you just let folks decide for themselves what's worth the hassle and what's not. We get it. You don't like hyd rollers in BB Fords. Sleep
Post  dfree383 September 19th 2017, 8:56 pm
JBR-3 wrote:Mr Freelander:
What valvesprings were in your engine ? Specs, if not secret ?
I don't remember the part number but they where a Circle track endurance roller spring, nothing crazy and we only needed to spin 7000 so didn't need anything big.
Post  dfree383 September 19th 2017, 8:58 pm
cletus66 wrote:
rmcomprandy wrote:Shaft or Bolt-down fulcrum rockers, (like the Yella Terra rockerss), will alleviate the sideways motion at the roller tip.
Otherwise ... don't use a hydraulic roller lifter in any BBF expectant of long term valve guide reliability.
For clarification...from the article....
“I don’t know how long I would trust them on the street,” Freelander said,
I have never had the opportunity to run them for 10-20k on the street and see how everything lives
Post  JBR-3 September 19th 2017, 9:17 pm
Last edited by JBR-3 on September 20th 2020, 1:29 pm; edited 1 time in total (Reason for editing : .)
JBR-3
Post  cletus66 September 19th 2017, 11:21 pm
Which is the nature of the Engine Masters Challenge. It worked for what you needed and made the power. How many guys get 20K miles out of an 800+ HP naturally aspirated mill anyway? It wasn't the point of your particular build. I love this stuff. I'm curious to see what kind of longevity Scotty will get from his hyd roller cams with solid roller lifters. He has been playing with that for a while now.
I have a whole pile of 572 parts that I have procured from Lem over the years, and I am watching every angle of this stuff. Actually, the only big thing I'm lacking is the valvetrain from the cam to the valves. I really appreciate what all of you guys do when you build these things.
Post  BOSS 429 September 20th 2017, 10:03 am
[quote="Scott Foxwell"]
BECAUSE I'm the other guy,I prefer to stop people from wasting their time, money, hurting parts, and killing a good engine.
Post  dfree383 September 20th 2017, 10:15 am
JBR-3 wrote:OK, maybe something like 200 lbs seat & maybe 700 lbs @ .800" lift ? Maybe jog a memory ?
225-250 seat 650-675 nose ish
Post  Wayne Pearce September 20th 2017, 11:02 am
I'm not an engineer by any measure, but it just "seems" to me that a Short body hydraulic roller lifter could be designed. One that would be no taller than a mechanical roller lifter, therefore reducing the side loading of the lifter bore, and the acute push rod angle to the point of being somewhat "acceptable". Am I missing something with my "pipe dream"? I would LOVE to be able to run a hydraulic roller 460 for a long duration in my 60 Starliner cruiser!
Wayne Pearce
Post  rmcomprandy September 20th 2017, 12:23 pm
Wayne Pearce wrote:I'm not an engineer by any measure, but it just "seems" to me that a Short body hydraulic roller lifter could be designed. One that would be no taller than a mechanical roller lifter, therefore reducing the side loading of the lifter bore, and the acute push rod angle to the point of being somewhat "acceptable".  Am I missing something with my "pipe dream"?  I would LOVE to be able to run a hydraulic roller 460 for a long duration in my 60 Starliner cruiser!
If it is to be a HYDRAULIC lifter then there needs to be a hydraulic mechanism inside the lifter so, put a roller on the bottom of a hydraulic flat lifter and that is what you get; a taller lifter pushrod button, by about 5/8 of an inch.
Post  Scott Foxwell September 20th 2017, 1:09 pm
LOL...
cheers
Post  dfree383 September 20th 2017, 8:36 pm
Scott Foxwell wrote:
LOL...
cheers
Guess the rest of us are the only ones moving up into the 90's at this point......
Post  68galaxie September 23rd 2017, 5:51 pm
True enough. The better hydro rollers (some are better than others) are certainly an option in this century.
However, saying solid roller lifter option is being stuck in the 90's is utter nonsense.
Solid roller lifter design is FAR better than they were in the 90's. There have been many advances in solid roller lifters over the last few years.
One must not think a hydro roller is the only lifter that will survive. It is more about lobe design and using a newer solid roller lifter design that will allow longevity not seen in the 90's. The bushing lifters have advanced, as have the needle designs - and materials used.
Sure running an aggressive lobe profile with a hydro or solid roller cam is not going to last 10's of thousands of miles. However, a well designed lobe profile for an endurance application along with a solid or hydraulic roller can be used with success.
What the hell do I know?
68galaxie
68galaxie
Post  dfree383 September 23rd 2017, 9:16 pm
It's always been about lobe intensity and spring pressures
And having realistic rpm expectations, big truck diesels have used solid rollers for years, but guess what, mild lobes, tight last, low rpm light springs and lifters designed and sized to go the distance.
Post  SandHillsHillbilly September 23rd 2017, 9:26 pm
Yes solid roller tight lash with mild lobes and reasonable spring pressures would be ideal but. How do you drive the oil pump and distributor without using a bronze gear as a wear item? I would happily run a solid roller cam if I could leave it untouched for 100,00 miles!! Don't mind adjusting valves.
SandHillsHillbilly
SandHillsHillbilly
Post  dfree383 September 24th 2017, 6:22 am
Run a single stage external pump
Post  Scott Foxwell September 24th 2017, 9:04 am
SandHillsHillbilly wrote:Yes solid roller tight lash with mild lobes and reasonable spring pressures would be ideal but. How do you drive the oil pump and distributor without using a bronze gear as a wear item? I would happily run a solid roller cam if I could leave it untouched for 100,00 miles!! Don't mind adjusting valves.
It's called an everwear cam core with an iron distributor gear pressed on the back of the cam.
Post  jasonf September 24th 2017, 10:10 am
Back of the cam??? Shocked
Post  BOSS 429 September 24th 2017, 11:41 am
lol, chevy guy,lolol Rolling Eyes
Post  BOSS 429 September 24th 2017, 11:43 am
LOL...
cheers
better check the date on your calendar, its the 2000s.
Post  BOSS 429 September 24th 2017, 11:49 am
We get a few years out of the gear, works just fine.
Post  BOSS 429 September 24th 2017, 11:50 am
seems there needs to be a like button somewhere here
Post  Scott Foxwell September 24th 2017, 1:31 pm
LOL...Freudian slip. Sorry. Rolling Eyes
Post  Scott Foxwell September 24th 2017, 1:35 pm
No more nonsense than saying a hyd. roller is a waste of time and money on a 385 series Ford.
Post  Scott Foxwell September 24th 2017, 1:37 pm
I was a Ford guy long before I was ever a Chevy guy. Truth is, I'll never be a Chevy guy. It's just what I work on most.
