572 A Head Engine
572 A Head Engine
572 C.I. A Head Big Block Ford
Ford Motorsport Block
Callies 4.500 Crank
Scat 6.700 H Beam Rods
Diamond Gas Ported 15:1 Pistons
Kaase Oil Pump
Comp Cam
Crower Roller Lifters
Trick Flow 360 CNC A460 Heads
Titanium Valves
Pac Springs
T&D Shaft Rockers
Tick Flow Mafia Manifold
MSD Distributor and Wires
Canton Oil Pan
Meziere Water Pump
Aerospace Vacuum Pump
Fluid Damper
25 Throttle stop runs on new bottom end including block and fresh heads with new intake valves. 10.90 @ 155 mph in 2850 pound car. 8.30's all out. Also have 598" short block back up if interested.
Contact Ryan 602-330-2709
Callies 4.500 Crank
Kaase Oil Pump
Comp Cam
Titanium Valves
Pac Springs
T&D Shaft Rockers
Canton Oil Pan
Meziere Water Pump
Fluid Damper
774 Super Street- Posts : 26
Re: 572 A Head Engine
$16,000 for the engine and $4,000 for the spare stuff
You're almost there to qualify for posting items for sale, but how about some more info on that 598 block.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
Motorsport block, with one sleeve. 4.600 bore, scat 4.500 forged crank, Callie's h beam rods, Diamond 15.1 pistons for A heads. Not assembled, I have rings and bearings. Rotating parts have 150 throttle stop runs on them.
Black has roller cam bearings also, will sell engine and back up short block parts together for $16,000
The intake is the new style i guess ? You said Mafia so i figured its the newer style but to clarify i believe the intake called the Mafia is for the oem style head.
nuclearcobra- BBF CONTRIBUTOR
The latest Trick Flow Manifold for the A Heads.
$16,000 for engine and short block spares
» 598 A-Head Engine
» 632 C head engine
» 521 A-Head Pump Gas Engine
» A- head engine builders
» 636 C Head Engine Complete
» 632 C head engine
