Wide Ratio Kit
Wide Ratio Kit Empty Wide Ratio Kit
Post  68formalGT November 11th 2017, 11:54 am
Frank Merkel, do you have a recommendation for a wide ratio C6 kit? I need to get one ready for your 2nd gear Trans brake.
Wide Ratio Kit Empty Re: Wide Ratio Kit
Post  68formalGT November 11th 2017, 12:14 pm
Does this kit work with your billet drum?
http://www.broaderperformance.com/ford-c6-/90-wide-ratio-gear-kit-with-needle-bearing-kit.html
Post  Frank Merkl November 11th 2017, 11:54 pm
it should
Post  Frank Merkl November 11th 2017, 11:58 pm
ask to make sure it has the steel 6 pinion front planetary
Post  68formalGT November 12th 2017, 9:24 am
Have you used wide ratio gearing in your transmissions before and if so how did they hold up? Are they as strong as the stock C6 parts?
Post  Frank Merkl November 12th 2017, 1:26 pm
haven't used the wide ratio yet , but we do go through front planetarys as we shut the the car off at 200mph every run and tow back so there is no oiling happening then , and I will have the 2nd gear brakes done this winter
Post  68formalGT November 12th 2017, 1:41 pm
Frank Merkl wrote:haven't used the wide ratio yet , but we do go through front planetarys as we shut the the car off at 200mph every run and tow back so there is no oiling happening then , and I will have the 2nd gear brakes done this winter
I hope I'm still on the list Very Happy. Let me know when it's done, I've got a fresh transmission with your billet drum (and the other one too) ready to go for next season.
Post  tzford February 4th 2018, 6:13 pm
I would get on the list for 2nd gear brake
tzford
Post  68formalGT February 4th 2018, 6:19 pm
Is it moving along?
Post  Frank Merkl February 20th 2018, 3:55 am
I'm not happy with the shift yet ! Not going to send any out until I have it perfect!!
Post  68formalGT February 20th 2018, 4:00 am
Awesome!! Sounds like you're getting it there!!
Post  gt350hr February 22nd 2018, 1:02 pm
I have two wide ratio transmissions. One is in my race car hauler ( F350 , 22 ft box) and really like it. It is a genuine needle besring Ford kit with the four pinion planets as the 6 was not available back then (14 years ago) . I just finished doing one I pieced together for my daily driver '67 Ranchero with 521 power. I used the needle bearing 4 planets with it too BUT it is not a dedicated race car and it doesn't have a manual valve body or trans brake ( obviously) . 6 pinion only for race cars .
gt350hr
Wide Ratio Kit Empty 2nd gear T brake
Post  Rick L March 20th 2018, 1:29 pm
Frank Merkl wrote:I'm not happy with the shift yet ! Not going to send any out until I have it perfect!!
I spoke to Frank today, hopefully I'm on that list also!
Rick L
