C6 Valvebodies
XEngr
manofmerc
C6 Valvebodies  Empty C6 Valvebodies
Post  Frank Merkl November 22nd 2017, 11:31 pm
I need of C6 valvebodies , as it seems that I've exhausted all the transmission dismantler stock . Vb's need to have the detent in the vb casting #'s on the upper half C8AP and on the lower half C7AP , let me know what you have and we'll talk price as I need 50 vb's at least
C6 Valvebodies  Empty Re: C6 Valvebodies
Post  FalconEh November 23rd 2017, 12:38 am
I have 2-BBF c-6's here Frank, I will pull the pans and check before I ship the other one.
Rusty
Post  Frank Merkl December 2nd 2017, 2:43 am
Come on Guy's
C6 Valvebodies  Empty value
Post  manofmerc December 2nd 2017, 6:19 am
Frank what are you paying for a detent valve body ?
manofmerc
Post  Frank Merkl December 3rd 2017, 4:49 pm
$100 ea
Post  XEngr December 5th 2017, 7:06 pm
What years of C6's have that valve body?  1967 to 1974?  Seems like the going price for C6 transmissions are around or over $200 for a core now.
XEngr
Post  aquartlow December 5th 2017, 7:57 pm
Frank,
I wish I could help, only have D7 and later VB's. For all the recommendations and info you have afforded me on my C6 ?'s, if I find one I would gladly send it to you for just the cost of shipping. I will keep an eye out for one, I realize it doesn't help you out much, but it's the best answer I have right now.
aquartlow
aquartlow
Post  DILLIGASDAVE December 12th 2017, 3:53 am
Frank, is the missing detent the only thing keeping you from using the later vb's? Or is there also other differences making the later vb's unusable?
Post  Frank Merkl December 13th 2017, 8:46 pm
the D2AP I use when building Custom transmissions as I can double up the detent spring and make sure the internal trans linkage is not tweeked by tightening the manual linkage against the 2nd gear band adjusting bolt and it's easy to do ! and then the manual valve in the vb will be in the wrong spot causing lock ups on gear changes and people don't like reading instructions
Post  Gregaust December 14th 2017, 6:29 am
Yes there is a point on the slider valvebodies than can lock 2 gears at once if not right between the valve and the detent. I have my measurements I do every one Smile
Gregaust
C6 Valvebodies  Empty Bump
Post  manofmerc January 10th 2018, 7:02 am
Just a bump for Frank .Frank I got your card the same day I called you thank a lot ! Guys help Frank out he pays on time and helping him allows others to have a great trans brake .Doug afro
manofmerc
Post  dfree383 January 10th 2018, 9:39 am
Need to start CNCing your own?
