429 cj engine 1970 and 1970 429 rug au toploader set up plus more
429 cj engine 1970 and 1970 429 rug au toploader set up plus more Empty 429 cj engine 1970 and 1970 429 rug au toploader set up plus more
Post  jadeezra December 19th 2017, 11:47 am
Northern Indiana can text pics 260-306-1977
C9VE-B block vinned was out of an early cj torino thin walled prior to nov 69 production they were using these . .040 flat top forged pistons, 4u crank, factory cj rods. Low miles on short block- $1200.00
Pair of D0OE-R Heads date code matched and off of above engine complete $1500.00
RUG AU 70 BIG IN BIG OUT toploader out of running car that shifted well but was pulled 15 years ago along with engine. Correct Bell included, original flywheel, clutch, bell, rods, shifter, manual starter, spacer plate, pretty much the entire set up minus the t handle $2400.00
Also have aluminum cj valve covers factory, cj oil pan, , 70 torino 4 speed hump, floor shift column, pedals
Would love to keep all this together for 4k firm . I can text pics thanks
jadeezra
